hi ya iv got a thermaltake armour lcs it cost about £139 (without p.s.u) about 2 years back. its got a good water cooling setup with a huge rad at front. it can be a little tricky too setup for the first time (it took me about 4hrs) but had too make sure every thing would fit 100%. the down side is the pump and the resvouir are place on the bottom of the case and even though you should get all your card and drives in ect ect.. I think sli or crossfire wont go due too the pump and resvouir. hope this helps.. p.s my m8 bought same case of e-bay for £85 in good nick too...
Oh god no. No. No. NO! Plastic shite. Everything TT product we've seen in as long has been plastic **** that's fallen to pieces while using it. There's only been one single CPU cooler that was worth buying.
I know that TT makes really dodgy case clones. But I was suggesting something relatively cheap. If not this then it would have to be the 1200 or the Cosmos.. Or God Forbid, the P193...
I have a 1200, its pretty good case. I have a SLI setup and its still cavenous. Solid, loads of room for water cooling ir required and it has one of the best thermal profiles around. Its also getting cheaper.
It's really really really terrible. Within 30 seconds we'd broken the Spedo, and building it ONCE we'd irreversibly damaged a dozen bits :S
If you can find one, A Lian Li AO5.... Its a small case, but can fit some very good watercooling loops, there is a really good thread on them here (XS Forums). Aaaand, its only about £70
