Modding Watercooling Fluid Shootout
Discussion in 'Article Discussion' started by Tim S, 16 Feb 2008.
  1. jmke
    jmke What's a Dremel?
    10 Oct 2003
  2. seanap
    seanap What's a Dremel?
    2 Nov 2007
    From the conclusions page...
    Great article, will definitely use this as a reference in the future!
  3. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    Any chance of Getting feser VSC amongst there? its even better than standard feser but you cant get it in UV :(
  4. zero0ne
    zero0ne Minimodder
    19 Jul 2004
    distilled water isnt conductive....
    the trace elements in faucet water is what makes it conductive.
  5. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    That's an unfortunate and grossly incorrect assumption. The problem is, it's founded in fact.
    Distilled water UNTO ITSELF is not really very conductive at all - you are correct. However, contact with ANYTHING and it begins picking up up ions. Air, dust, motherboard...it becomes instantly conductive. Each of these NCFs are treated to prevent metal ions and other conductive methods from being reactive once their ions are brought into the fluids.
    I assure you, and you may test it if you'd like. Pour some pure distilled water on your hardware - it'll fry in very short order.
  6. NoahFuLing
    NoahFuLing What's a Dremel?
    18 Jun 2005
    As a preface, I've been needing a comparison like this for a long time, and you guys wrote an excellent article. Plus, kudos to everyone who didn't say anything like this before.
    Since nobody else did it, I guess I'll be the first. :naughty: :hehe: When I read the title, I read it as "Fluid Shootout" and I almost spat water all over my keyboard (ironic, I guess).
    But yeah, definitely a really helpful article. I'm definitely surprised that FluidXP did so badly (well, compared to the rest), but the fact that the Feser did so phenomenally gives me great confidence in planning to use it in my first water-cooled adventure (well, serious watercooling, anyhow, my first try lasted a week and was not at all successful). Thanks guys, you wrote a brilliant article and the title made me laugh hysterically for a minute or so. I guess I'm still entirely immature inside. :sigh:
  7. radodrill
    radodrill Resident EI
    14 Mar 2006
    I would have liked to see long term results with the fluids; in particular fading characteristics and if the dyes/additives will separate out and stain the tubing.
  8. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    In RE the metal buildup, does anyone filter their fluid? Seems like a good idea.
  9. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Wow fesser is fast to add the bit-tech award to their website. Are they lurking the worldwideweb for previews.
  10. Jipa
    5 Feb 2004
    I lol'd.
    Feser one - Almost as good as distilled water!
    Yeah I know there are also other aspects involved and not just the load temperatures, but I just found the award of excellence a bit funny :)
  11. [USRF]Obiwan
    9 Apr 2003
    Well dont know about your wc setup, but i have to refill mine 2 wc pc's once or twice a year because the dye vaporizes. And no, i dont have leakes. So to answer the question. It will last till you have to refill
  12. WhiskeyAlpha
    WhiskeyAlpha What's a Dremel?
    5 May 2006
    Been using Feser One for a while now, it's great stuff.
    I use the UV Green and UV blue coolants in my two loops. The only thing I noticed was that my UV Blue coolant was barely reactive at all (particualrly when compared to the UV Green).
    How well did your UV Blue Feser One react to UV light? Anyone else had experience with the UV blue stuff?
  13. Guest-16
    Guest-16 Guest
    That and we let companies know how well they do in reviews - not just to alert them to awards but to give feedback on how they can make better products and the problems (if any) we had.
  14. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Id say the Blue UV Feser one works well with UV light :thumb:
    UV off
    UV on :D (pic taken during leak testing)
    I can also confirm that this stuff wont fry your mobo when it leaks, or more to the point when accidently spill some. :duh:
  15. WhiskeyAlpha
    5 May 2006
    Cheers Delphium.
    Though to be honest I think it looks much like mine. The main UV effect is created by the UV Green coils you're using. Judging by those pics the UV Blue looks nowhere near as "vibrant". Maybe it's just the contrast that's fooling me but my UV Green Feser looks much brighter under UV light than my UV Blue stuff. To be honest those pics look about the same as mine.
  16. WhiskeyAlpha
    5 May 2006
    Ah, look here,
    So it's not my imagination after all :D. Looks like the UV Green is particularly reactive, particualrly obvious when placed next to the blue.
    When I used to use Zerex and UV dyes (back in the good old days :)) it was far more vibrant than the Feser One UV Blue.
    Looks like I might be going UV Green in both loops.
  17. Delphium
    18 Mar 2007
    Hmmm intersting the green is much brighter/vibrant :)
    Know what ill be going with next time =]
  18. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    or you could add some of the more vibrant dye. no reason it shouldn't work as I see no chemistry that could go horribly wrong.
  19. WhiskeyAlpha
    5 May 2006
    Yeah, I did see another comparison somewhere where the blue one did look a bit brighter than the link I posted. Still not a patch on the green stuff though.
    I'm not sure about this Bluephoenix. I have no clue when it comes to the chemistry but IIRC, when I used to use distilled water, UV dyes made the coolant more conductive (or was it the corrosion inhibitor?).
    Even Feser One comes with stern instructions not to mix colours/dyes as it can jeapordise the "non-conductiveness".
    In fact, I bought a bottle of the Feser One UV Blue dye to try and "spice-up" my blue coolant and it made no noticable difference after adding the recommended amount.
  20. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    da dego is correct, however distillized water has been used in wire EDM machines for 20 years, where resistance is an important feature, and while it's true it will become conductive over time, conduction is relevant. What's the measure? as conductive as air, less? more? Actually you can tell if the water in an EDM machine is getting dirty as when you stick you finger in you'll get a slight tingle. Caution though the brass wire carries enough juice to kill you.
    Good review, I never used non conductive cooling in a loop and over the years I drenched my motherboard and video card repeatedly. I just turned off the power nad blotted and thoroughly hair dryed the mobo and I never killed a piece of hardware.
Tags: Add Tags
