Cooling watercooling help
Discussion in 'Hardware' started by warrmr, 3 Jul 2004.
  1. warrmr
    warrmr What's a Dremel?
    5 Nov 2003
    if i were to buy This how would i go about mounting teh CPU block as all teh watercooling gear is geared around having 4 holes in your mobo. my board doesnt have these holes. so is there some kind of hold down device i can buy or comes with the kit to mount to the socket lugs.
    bering in mind i havent got a removable mobo tray on my case (chieftech matrix and haev limeted room to manuver the device into place. (was a pain in the ass to mount my areo7 )
    [​IMG] something like that is what i am looking for and woudl it fit on the waterblock supplyed with the kit
  2. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    Don't think there is anyother method of mounting that perticular block.
    See here(middle of page for blocks with SHD (socket hold down)
    Cheers,
    Mike
  3. warrmr
    5 Nov 2003
    thanx for the advice there now to either go find some 1/2 - 10mm reducers or buy a 1/2" wc kit.
  4. pauldenton
    pauldenton What's a Dremel?
    8 Feb 2004
