Case Mod - In Progress [WaterCooling Project] The Ms. White @TJ07 is Finished :D
Discussion in 'Project Logs' started by r1sKas, 25 Jul 2011.
  1. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Hm.... lots of nice hardware, but no so much modding up until now. Get going, will ya? ;)
    Oh, and I'm looking forward to seeing how the non-painted alu on the inside will match the fittings. At first I thought "This is a mistake", but now I'm actually looking forward to see how you'll pull it off.
  2. r1sKas
    r1sKas Orange or White? Lets mod!
    22 Jan 2011
    Ya ur right....
    The modding will start soon, and i hope the non-painted alu fix good with fittings xD
    Cheers
  3. r1sKas
    22 Jan 2011
    Today arrived my frontal and a few pieces for the build
    White acrylic piece to the EK cpu block :D
    The front panel:
    The little box with white leds ;D
    WOOOOOOOOOOOW :D
    My lightbox, with 1m of white leds
    and the 2 top acrylics
    I'm gonna paint the frontal to match the rest of the case, will be hard, but lets see how it will be
    Soon more pics!
  4. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Where did you get theese masterpieces ?
  5. r1sKas
    22 Jan 2011
    This was made in Coldzero, by Patuga :)
    Really love the waterblock acrylic!
  6. r1sKas
    22 Jan 2011
    I will try to paint in the same colour now, first the primary, then the same as the case.
    Here we get a few pics of the midplate "mounted", but still miss some cuts for the WC.
    Also i'm waiting from the Bitspower repply for the fabulous fittings :)
    Cheers
  7. Snowcrash
    Snowcrash New Member
    10 Nov 2011
    good looking rig, very clean!
    looking at the top of the front panel, I assume you're planning to use a slot-load DVD (or blue-ray?), but where do the eject button+activity LED go? are you not using them? also, which slot-load brand are you using? I've been looking into this but there doesn't seem to be much selection and people seem to be having lots of problems with them (drivers, etc.).
    In the meantime, keep up the good work :rock:
  8. r1sKas
    22 Jan 2011
  9. kicklOp
    kicklOp New Member
    27 Dec 2011
    I assume he'll be doing it thru software, for example: right-clicking the device in My Computer and then selecting Eject...
    By the way - Great thread... :thumb:
  10. r1sKas
    22 Jan 2011
    Ur right :)
    I spend an hour for removing the letters from the front, and was hard, but is done :)
    Next week it goes for the paint to match the case :D
  11. r1sKas
    22 Jan 2011
    Wich one, 1 or 2??
    I m8 choose the 2, but with push and pull in the 240 radiator, adding 2 more fans, the 7 and 8, because its for CPU.
    So 4 in 480 and 4 in 240.
  12. KoSoVaR^
    19 Dec 2010
    1.) Better performance
  13. r1sKas
    22 Jan 2011
    And what about the tubing? could be kinda hard to handle no?
    Take a look to this fantastic Phanteks thanks to Mike from Phanteks that helped me with those ;D
    The looking Ram's Avexir
    Nice? :D
  14. Nutman
    21 Oct 2008
    Martin's liquid lab made a pretty in-depth test of all kinds of setups involving push/pull and shrouds:
    http://martinsliquidlab.org/2012/01/15/radiator-shroud-testing-v2/
  15. Nutman
    21 Oct 2008
    Also, those fans look VERY interesting! How's their performance and noise level?
  16. dirky90
    dirky90 Member
    19 Mar 2012
    you got a black lamptron fc5!?!?! where from? i cant find one anywhere!! its looking very sleek!!
  17. r1sKas
    22 Jan 2011
    Well,
    They dont have the airflow from like a Xigmatek (those are really noisy), but im very satisfied with those fans from Phanteks... i need to compare it with some BeQuiet SilentWings i have here :)
    Cheers
  18. r1sKas
    22 Jan 2011
  19. r1sKas
    22 Jan 2011
    this week we are going to have some updates...
    some fittings arrived and i need to get a way for the fittings space on the midplate...
  20. r1sKas
    22 Jan 2011
    Hi,
    My repainted front painel just arrived... i think this is the best we can do. It was painted 2 times, and i think it from the case was black, so it makes a "dark white" in the case... what doesnt happens in the acrylic.
    Bitspower on the way!
    Over 50 fittings
    My little spy ;D
    The Lampton FC5 and dvd drive slot in holes
    News soon!
