Watercooling , PSU
Discussion in 'Hardware' started by WaLLWaLLa, 11 Aug 2005.
  1. WaLLWaLLa
    WaLLWaLLa What's a Dremel?
    12 Jul 2005
    Erm...yes , i have a question , Do you think the Beantech BT-82 Acrylic case - ( http://www.themodhouse.co.uk/store/...d=264&osCsid=8ffcc53dbed00ea941ec53c3e97f4bfe ) , Do you think that case on that link wud be able 2 accomadate this dual 120mm water cooling kit - ( http://www.overclockers.co.uk/acatalog/Complete_Kits.html ) , - its the 2nd 1 down the page-. My question is , do you thnk the beantech case wud be able 2 accomodate this watercooling kit , taking into consideration PSU space , which shud be roughly 15-17cm (i shud be using antec neopower 480w PSU) , drives arent a problem cus i cn move thm down a couple of bays so i have space towards the front alot more.
    I think this wud be a tight fit fitting those 2 fans on the top of this case , and would it be a tight fit inside due to wires and pumps etc?? , just wondered if any1 cud help really , thnx. :thumb:
