Cooling Watercooling questions
Discussion in 'Hardware' started by blueviper11, 12 Sep 2012.
  1. blueviper11
    blueviper11 What's a Dremel?
    9 Sep 2010
    Hey everyone, I'm new to watercooling and plan to set up a new rig next year hopefully. I'll be buying a watercooling set to out into a Cooler master HAF X.
    How often will I need to change the water in the system?
    And is there any specific important information that I need to know?
    Thanks a lot. :D
  2. Dopeyman
    Dopeyman Minimodder
    10 Jan 2011
    Have a search for bloody_pete's guide, it has lots of very useful info.
  3. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    I change mine every 6 months, but 8-12 is acceptable.
    Do some research on the net, read a few guides including bloody petes.
    However much you budget for.....it will cost more, and however long you think it will take.....it will take longer. Or at least if your anything like me lol.
  4. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Absolute bare minimum budget is £300, and that's if you're really skimpy with parts, you'll likely wind up spending more, dependant on what you want to plumb into the loop.
    Firstly; Always plan for worst case scenario, this means: Have a drain line setup. It doesn't matter if you're filling from a reservoir in the top of the case; if there's a leak in the middle; you need a way to get it all out as fast as possible. I find a T-line at the lowest point usually works best, stick a plug in the spare hunk of tubing and simply remove when you need to drain.
    Secondly; think about how you're going to fill. Ideally; you want your input point to be at the highest possible point in the case, and the shortest possible route to the Pump possible, so you can get a lot of liquid in, and don't have to cycle the pump so much. It also helps bleed air out of the loop a lot faster if your input is at the top.
    GeorgeK likes this.
  5. blueviper11
    9 Sep 2010
    I took a look at your system and am aiming for the same set up - it looks very nice.
    Great advice there, will definitely keep these points in mind.
  6. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    QFT! (especially when the measurements for your fabricated panels turn out to be wrong ;) )
    Its expensive and yes it takes longer than throwing an AC system together in an afternoon but its also very rewarding when you see those temps. Go for it but be prepared to stretch your budget.
    I found this guide to be the most complete and most useful, pretty much followed it word for word and have had no problems yet:
    http://www.clunk.org.uk/forums/water-cooling/33772-water-cooling-guide-beginners.html
  7. bdigital
    10 Aug 2010
    Lol you got me there !. Measuring never has been my thing but i got there in the end!
  8. Nexxo
    23 Oct 2001
  9. GeorgeK
    18 Sep 2010
    I've always wondered about these two points and never really managed to get such a good answer! +rep!
    Would it help to have the pump high up too then?
  10. David
    7 Apr 2009
    You don't need to. As long as you have a direct, unrestricted path from res to pump, with the pump no higher than the res outlet, all will be well.
  11. GeorgeK
    18 Sep 2010
    Ah ok then - thanks for the reply. I'm not thinking about WCing any time soon - just good to feel that I have some knowledge if (when) I do take the plunge (so to speak).
    GK
  12. blueviper11
    9 Sep 2010
  13. .//TuNdRa
    12 Feb 2011
    Basically; you want the reservoir above the pump, with a straight-ish hunk of tubing connecting the two, so you can completely fill the Res, then start the pump, then fill the Res again if you need more fluid.
    While it might be neater to, say, have the pump at the other side of the case; it makes filling a pain in the arse. Not to say it's not possible, but having the two as directly attached as possible and gravity assisted where possible makes life a hell of a lot easier if you have to fill it.
  14. blueviper11
    9 Sep 2010
    Read Mattewrblack on "loop check".
    That seems a lot of radiator to the loop ,just for CPU N Graphics Cards is it worth put more 2 on it??
  15. bdigital
    10 Aug 2010
    Cpu, gpu and mosfets under water with a single quad rad here. Temps are very good :)
  16. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Nexxo's one is oooooold :p Mine is much newer (and highly praised) :) Link in sig :)
  17. blueviper11
    9 Sep 2010
    Thank you. Bloody_Pete:rock:
  18. law99
    law99 Custom User Title
    24 Sep 2009
    Bloody_pete and youtubing DazMode helped me a lot. Read, read, read, read though. That is what you should do before you start.
