Cooling watercooling setup help
Discussion in 'Hardware' started by Archtronics, 18 Jul 2006.
  1. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    well since i dont seem to get any more answers for my old thread heres a new one can some one show me how to conect a watercooling kit together that has two resviors
  2. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    pump-rad-blocks-res top-res bottom-pump
  3. trati629
    trati629 Can I Fix It? :$ Well Yes??
    13 Jun 2005
    Hi i would do the following
    RES***RES
    Pump***Pump
    CPU***GFX GFX
    Voltage***North
    Block*****Bridge
    RAD
    RES***RES
  4. Firehed
    15 Feb 2004
    I don't know where your old thread is, but I'd basically do as above, but have the GPU blocks sequential. Having a Y fitting to split flow is asking for problems - uneven flow is created, and there's always a chance that you'll end up with a spot of still water, and that'll kill stuff. So something like:
    Res 1 -> Pump 1 -> CPU -> MOSFET -> NB -> Rad -> Res 1
    Res 2 -> Pump 2 -> GPU1 -> GPU 2 -> Rad -> Res 2
    Depending on the type and position of the res, it may also be possible to have them sequentially. If one can gravity-feed to the other, it should work.
  5. Archtronics
    27 Jun 2006
    thanks i going to buy a new setup could you advise me on were to buy what do you think of xspc watercooling
  6. LVMike
    LVMike What's a Dremel?
    11 Aug 2004
    out of curriosity, why two reses?
  7. Archtronics
    27 Jun 2006
    because id like the look havin 2 res and gives me option to upgrade to 2 cooling loops in the future
  8. Xavierthefirst
    Xavierthefirst What's a Dremel?
    17 Jul 2006
    u can basicly stick em anywhere as long as your not losing any pump pressure, and if you can fill them extremely full even that can be stopped
  9. hydro_electric_655
    13 Jul 2006
    Putting a radiator between the CPu and GPU's imho is just as effective and cheaper than 2 loops. But then again 2 times the stuff is fun.
  10. Archtronics
    27 Jun 2006
    yes but say i set up the gpu later on, that means iv got to empty the system and rebleed it of air
