Cooling Watercooling Setup, Some advice
Discussion in 'Hardware' started by desertstalker, 5 Aug 2007.
  1. desertstalker
    desertstalker What's a Dremel?
    7 Feb 2004
    I am planning on putting together a watercooling setup for my PC.
    Specs:
    E6600
    Asus Striker Extreme
    2x 8800GTS SLI
    I have chosen the following components (prices are in Australian Dollars):
    Swiftech Apogee GTX Waterblock $109.00
    Swiftech MCP655-B 12V Pump $139.00
    Hardware Labs Black Ice GT Stealth 360 $125.00 Barb Size: 3/8
    Swiftech MCRES-MICRO Hi-Flo Reservoir $35.00
    Sub-Total: $408.00
    I will add a pair of GPU blocks as soon as I can source them (seem hard to find in Australia). Please don't suggest different parts unless you know where i can get them within Australia, I do not wish to order from overseas.
    However I have some questions:
    1) I wish to use 3/8" tubing, is that going to work with this setup (the MCP655 has 1/2" fittings AFAIK)?
    2) Can threaded be inserted through the radiator, I intend to mout the Rad above the top of the case (or out of the back) using threaded rods?
    Finally if anyone have any advice or general tips i would much appreciate hearing them.
    Thanks in advance.
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    1. you will need a reducer
    2. what ???
  3. radodrill
    radodrill Resident EI
    14 Mar 2006
    1) I'd very much recommend using 1/2" tubing rather than the 3/8; results in a less restricting loop and better performance. Most/all waterblocks/rads are threaded to accept either 3/8 or 1/2 barbs; only the pump has integrated barbs.
    2) You can't run all-thread all the way through the RAD; but you can thread screws/all-thread into the holes on either side.
  4. desertstalker
    7 Feb 2004
    Is there alot of difference? I was planning to run 1/2" between res and pump to reduce flow, but was worried it would be difficult to route tubing if i used 1/2" ID especially when fitting the GPU blocks to the lower card (there is about 5mm between the default HSF and the bottom of the case - antec p180).
    The swiftech kit with the same pump used 7/16" ID tubing and that fits over the pump, so maybe i could use that.
  5. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    The difference bewteen using larger tubing and smaller ID tubing is minimal: Thread by Cathar over at XS forums
    I would try and source a Thermochill rad if you can over there or if not a Swiftech one rather than a Black Ice as you will then be able to use lower CFM fans and achieve similar cooling quieter. Regarding sourcing them over in Oz i would post on the OCAU forums as everyone there will know the best places to source watercooling stuff where you live. Linky
    Hope that is helpful. :)
  6. desertstalker
    7 Feb 2004
    According to this, there does not appear to be a huge difference in performance between the swiftech and the BI GT
    http://forums.bit-tech.net/showpost.php?p=1510015&postcount=10.
    Re the thermochill rads. They are available in AUS but at very high prices. I can get a 120.1 for a bit more than the 120.3 Black ICE. AFAIK even with very low CFM fans the BI would be better.
    eg. here http://www.gammods.com.au/store/index.php?main_page=index&cPath=1_2 (I got this site from atomicpc forums) and Google shows no lower prices.
    The biggest question I have is how / if it is possible to use 3/8" tubing with the MCP655.
    Thanks
  7. Krikkit
    21 Jan 2003
    Thermochill PA's are the best low air-flow rads out there, still. Shame they're expensive.
    There isn't much difference at all between 1/2" and 3/8" anymore - I'd just use 3/8" and buy 1/2" barbs for extra security, 3/8" tubing creates a really nice, tight fit on 1/2" barbs.
    For rad mounting it's difficult to say if the bolts will go through the rad - they might do, or they might not - if there's a min-tube thingy in the way (forget the proper name) then it's best not to try.
