Cooling watercooling tubing that won't degrade under UV light???
Discussion in 'Hardware' started by MbayAQ, 25 Nov 2003.
  1. MbayAQ
    MbayAQ What's a Dremel?
    10 Feb 2003
    What kind of tubing is impervious or nearly impervious to degrading from being exposed to lots of UV light?
  2. penski
    penski BodMod
    29 Aug 2002
    *Shifts to Watercooling*
    *n
  3. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    I'm pretty sure Tygon is at least UV resistant because even with 2 UV cathodes next to it, my UV dye dosen't even glow.
    Take some of the water out and BOOM! Super glowage, so, yeah, Tygon's probably the stuff.
  4. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    The fact that the UV isn't getting to the water implies that the tygon is absorbing the UV radiation. This is probably not a good thing since the UV must be absorbed for it to do any damage. In fact, it is often the action of causing dameage which "absorbs" the UV.
    Something which is "transparent" to UV is less likely to be damaged.
    All that said, I couldn't tell you for sure either way.
    8-ball
  5. ndtinker
    23 Sep 2002
    That's a good point..hadn't thought of it that way.
