Watercooling Watercooling woes
Discussion in 'Tech Support' started by Lassar, 5 Mar 2012.
  1. Lassar
    Lassar Lean Mean Fighting Machine !
    16 Jun 2009
    Had my 1st Watercooling loop together for a whille now and TBH im a little concerned.
    All is well .... however looking in my res last night I noticed around the fill line a white line has formed..... and there a couple of floating white things. Also looks like there is an oil slick on the top of the water..... Any ideas?
    Using Mayhems Dye X1 Premix as coolant which I was assured had all the nessacary stuff in it.
  2. mav2000
    mav2000 In Training
    16 Oct 2010
    Did you clean the rads well before installing the loop?
  3. Lassar
    16 Jun 2009
    im assured they were.... perhaps not.......
    Any ideas how to deep clean?
  4. Gurdeep14
    Gurdeep14 Minimodder
    25 Apr 2009
  5. Apocalypso
    Apocalypso Fully armed and operational.
    15 Sep 2007
    This is a pretty good simple guide as not everyone has a load of expensive pumps and filters .
  6. mayhem
    mayhem Owner of Mayhems
    12 Sep 2008
    Hi there
    In a new loop with new tubing normally its can be 1 of several thing or a multitude of all.
    1) Plasticizer from new tubing. (signs of this is a whitish substance layering on top of the res and cloudy tubing). If not cleaned out will cause build up eventually around the pins of any water cooling block. This is what people normally think is caused by dyes of liquid which is untrue.
    2) Manufacturing solder and or flux in the rad. This normal is a green / blue texture that is present in ALL new water cooling rads. If not cleaned out will cause problems.
    Many people use sysclean to clean this out of there system how ever i personally dont think its a good idea on Plated blacks as it eats away of the blocks because of the acid in sysclean. The west cost mods method is the best way to clean out you system bar none. its natural and it doesn't use chemicals.
  7. Lassar
    16 Jun 2009
    Rads were used ... tubing is new..... never knew you had to clean tubing 1st !!! Doh !!! Looks like i need to order me some more Mayhems :D
