Scratch Build – In Progress WaterCube *Update 19/04/10*
Discussion in 'Project Logs' started by haofeng, 23 Mar 2009.
  1. stuartwood89
    20 Aug 2008
    I think the only time people mind is when they're trying to read a post half way down the page, and suddenly everything jumps about cause the images from previous posts above it suddenly load.
  2. tominated
    tominated What's a Dremel?
    28 May 2008
    looking really nice. love your work!
  3. haofeng
    haofeng What's a Dremel?
    9 Jun 2008
    yay! new page started! :D
    Sorry if I dont thank you personally for all those great comments guys, I recon getting on with the project would make y'all happier...
    tyrandan: I havent decided yet, but its gonna be whichever way it is easiest to set up the tubing. Anyways, contrary to common misconception, apparently, it doesnt make any difference which way the water flows, since then temp in the entire setup is uniform. Can't remember where I read it tho...
    update soon...
  4. haofeng
    9 Jun 2008
    update 4-DISASTER!!
    I decided to test fit the top panel just now and....disaster!
    Somehow, the lip I bent managed to be a few degrees off the perpendicular to the sides of the top panel, if you get what I mean. So when I line the lip up with the rear of the case, the sides are slightly askew. I have no idea how I managed to bugger this one up! :wallbash::wallbash::wallbash:I think this was more a problem with my marking out then bending.
    A few pics to demonstrate the problem
    The lip matches up like so
    But the sides are askew
    A close-up of the problem. I recon its about 5mm off
    And conversely, when the sides are parallel to the frame, the lip doesn't fit properly anymore
    I think I might have to chop off the lip completely, trim the top panel a bit so that the sides are parallel, and then probably attatch some alu angle to the back to make a lip. Anyone got any good solutions?
    I'm considering making a new top panel, but then that would be very time (and money) consuming...:sigh:
  5. waynespartan
    waynespartan What's a Dremel?
    25 Jan 2009
    looking good
  6. haofeng
    9 Jun 2008
    Update 5
    I've decided to postpone the correction on the top panel, and have a think about what to do-though to be honest, i dont think there are many options open to me.
    Anyway, I got on with the frame, and the motherboard support, as well as the support for the piece of alu which divides the top and bottom sections.
    some cutting...
    Heres the finished frame
    Side view
    The joint with the rear piece of alu angle
    Heres the join with the front piece. I havent actually joined the small piece of alu angle to the front piece yet, I will be using masking tape for the time being. This is because I dont want to screw the piece in since it'll mess up the look of the front panel, so I think I will use some epoxy glue (araldite is what I'm thinking), since alu doesnt like to be welded. Does that sound like a good idea? Any better methods?
    I'm pretty pleased with how the frame has come out, and now I need to fabricate the divider piece, and the pice which supports the m/b. More on that later.
    I decided to do a rad mock-up to see how much space I have to work with internally, and seems its gonna be pretty tight in there.
    Front view...damn I love those rad grills
    Not much space between the m/b and the rad (sorry the m/b tray looks in such bad shape, hopefully it'll be fine once I finish the support), so I'm gonna have to be careful when I come to do the tubing for the watercooling. This is pretty close to the pic I had on sketchup.
    Now for a top view- demonstrates how little space I have. I know the m/b tray is askew, but it will be good once I secure it a bit better.
    And for a summary of most of the progress I've made so far
    Will have some more work up soon...
  7. tjay@TJ
    tjay@TJ Minimodder
    4 May 2008
    great job with the scratch build:thumb:.
    sorry for the disaster.
    my suggestion is to bend a new piece. well looks is mor than anything. but than again, if it can be fix, why not.
  8. Tungil90
    Tungil90 What's a Dremel?
    29 Nov 2008
    looks promising!
    keep it up;)
  9. tyrandan
    tyrandan Pink Lemonade.
    2 Mar 2009
    Sorry about that botched bend man. If it were me, I would just save up the moolah and get a new piece to bend, and work on other things while saving up. Good job so far though, Ilike the rad grill too :rock:
  10. Denrik
    Denrik What's a Dremel?
    2 Mar 2009
    Nice build mate, I would go with bending a new piece as well hey, may as well do it right, get it over with.
    Hope it all comes together for you.
    Dan.
  11. haofeng
    9 Jun 2008
    Sorry for being away for so long, well, i cant reli do much modding at skl, and for the last month or so, ive been on the other side of the pond.
    Anyway, i've got some exciting new bits and hopefully progress will be quicker from now on. I aint got any pics on yet, but ill try to get some up by tonite- ive managed to get most of the panels more or less done. Im hoping to get this thing finished by the end of the hols.
    Haofeng :D
  12. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    Hey man nice build should look the nuts when it's done :D
    How about putting a hinge on the lid??
  13. haofeng
    9 Jun 2008
    Update 6
    Ok, here are the promised progress pics.
    First off, I made the motherboard support and the divider piece
    Heres a closer pic, tho i didnt manage to get my crappy camera to focus properly
    I bought a faulty mobo on ebay for some mock fits etc for a couple fo quid. It even came with a P4 cpu inside it, whichwas a nice surprise...i guess ill use it as a desktop ornament or smthing. I fiinished the rear panel- there r four cutouts on it for the 80mm fans, and the psu/ mobo holes r cut out too.
    The rear view makes it a little clearer...
    Thumbscrews holding it all together
    After a lot of time spent with a file...i got the side panels cut and filed down to size. The end result was pretty good in my opinion tho. its still held to the rest of the case with a little masking tape-im gonna have that sorted out soon.
    again, the focus was bad, but decent fit, perhaps a little sanding will make it a little better...
    rear view
    I just need to cut out the side panels to fit the fans. i picked up a couple of rad grills while i was in the us, it should look pretty awesome.
    I got the top panel sorted too. I reli couldnt face up to making a new top panel, so i went with the chopping off the lip plan. then i added a pair of alu angle pieces to attatch it to the rest of the case.
    The alu angle is attatched to the top panel with araldite...im hoping itll b strong enuf.
    I also added a lip to the front of the panel (again, araldite). This should keep the toppanel from coming out to place.
    Slides under like so (sorry about the crappy pic)
    I forgot to take a pic of all the panels attatched :duh: will have one for u next time
    well, thats it for now, i think the main bits on the actual case still to do are
    1. HDD rack
    2. Front I/O panel and switches
    3. secure dvd drives and fan controller
    4. cut fan holes onside panels
    5. powder coat
    and then comes the actual build...:D
    thats all i can manage today, will show u some of the goodies i picked up in the US next time :thumb:
    @woody- i did think of using a hinge, but think my present solution will suffice, so i dont think i will bother with all the complications that come with it.
    Over and out
    Haofeng
  14. haofeng
    9 Jun 2008
    Update 7
    first off, my new workspace- we moved house, so i now have what used to be the study in the new house allocated to my modding needs :D
    all nice and clean...for the moment
    and i got this new work bench/shelf unit which i recon will come in useful...
    check out my new toy :D
    215 drill bits i all its glory...
    speaking of new stuff, i got another one of these babies to keep mine company...165 bucks from newegg with CoD 5 in tow, too good to miss
    in all its naked glory...
    more toys
    this should come in handy when it comes to doing all the wiring
    and finally, some more radgrillz
    Im a big fan of the hexx mesh- this will be going on the side panels
    now for cutting the actual holes for the radgrills- templates glued on with some old fashoined pritt stick
    lots of conviniently placed holes for my jigsaw
    ...and after some hard-core jigsaw action
    I did the top panel hole for the window while i was at it
    et voila!
    thats all i had the time to do last night. I guess i have a good amount of filing to do today...will have an update tonight.
    now i need to contact watercoolinguk to see if i can get this powdercoated- i think they do a pretty good, reasonably priced service. hopefully, the masking tape is gonna b coming off over the next few days and ill be sending the whole thing off for a lick of paint. :D
  15. Jipa
    5 Feb 2004
    Really nice, compact design and good work with the aluminum. Keep it up.
  16. haofeng
    9 Jun 2008
    Update 8
    I did some filing plus a couple of other bits and pieces this afternoon
    Filed lovingly...its as near perfect as i could have hoped for
    Drilled the holes
    and...perfecto! you cant really see from the picture, but the holes match up pretty well. Im still waiting on a shipment of screws, so will have a test fit soon
    side panels mounted
    and now with the top panel on too. i filed that one as well.
    well, at least im pleased....:D its all beginning to come together at last.
    im gonna see if i can get the I/O cutouts done tonight as well...
    jegerjon likes this.
  17. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    this looks pretty sweet haofeng. +rep for incredible patience with jigsaw and file! ;)
  18. Richh999
    Richh999 Small Time Modder
    9 Oct 2008
    I'm loving what you've done already.. What are the other goodies you going to put inside of this awesome case? I've always wanted to build a dcase identical to this and cannot wiat to see how it turns out....
  19. haofeng
    9 Jun 2008
    Update 9
    thanks guys, much appreciated.
    @rich999- all in good time...:p
    I had an early night last night, so didnt do the I/O plate. Got it done this morning though
    It was a little challenging to cut the hole for the I/O plate because it was kinda small, but i managed it. unfortunately, i had to call on my old friend Mr File again...
    well, heres the actual I/O plate, the Silverstone FP32- looks nice, and not too expensive, i think i picked it up for a tenner or so.
    heres it fitted, along with my vandal resistant switch. damn those things r expensive!
    i havent mounted the I/O shield yet, i need to think up a good way to fix it to the case
    thats all for the moment, will do some more work this afternoon.
  20. haofeng
    9 Jun 2008
    Update 9 and a bit...
    I got the fixing bracket for the I/O plate done...
    I had to chop a bit off the I/O plate cos it was in the way of the side panel fans, and then i used the chopped off bit to make the bracket...recycling at its best :D
    (electrical bits removed in case of damage)
    and i also contacted watercoolinguk and got the powder coating more or less sorted- satin black here i come!
