A/V Waterproof Hi-fi.
Discussion in 'Hardware' started by warchild, 29 Mar 2006.
  1. warchild
    warchild What's a Dremel?
    30 Jan 2006
    I would like to know if you guys know something about this matter.
    Not only about waterproof speakers but especially about waterproof hi-fi.
    Tanx.
  2. fiend666
    fiend666 What's a Dremel?
    8 Mar 2006
    hello mate i would go through bathroom/marine suppliers and see what they can do,
    some jaccuzi large baths come with them fitted and you may be able to source the components,
    there used to be a few bits made by bose mainly speakers i think the speakers are going to be easier to find
    what were you thinking of doing?
  3. warchild
    30 Jan 2006
    Hey fiend666,
    well i live in a condominium with a small swimming pool, and i was thinking if there was possible to put some waterproof hi-fi near the pool ?! :naughty:
  4. Mister_Tad
    27 Dec 2002
    A friend of mine had a pair of Bose 251 speakers in a room with a hot tub in it. Theyre good for outdoor use as well and could apparently work underwater too (or so we were told)
    You could just get something like that and keep the electronics in a cupboard or better yet, inside
  5. fiend666
    8 Mar 2006
    sounds like a cool idea, should be possible as said above to sort waterproof speakers and do the electrics not to far away,
    is your pc close enough to wire up or could you use one of those audio/video wireless senders then you could have mp3/internet radio/playlists and cd and it would cut down on the price of the electrics?
  6. Atomic
    Atomic Gerwaff
    6 May 2002
    Surely those 'outdoor' speakers that survive rain and snow would do...
  7. warchild
    30 Jan 2006
    All the ideas are good but the big issue here is the "possible waterproof hi-fi" is for the use of all the persons in the condominium :rolleyes: ( 20 persons total ), not only for myself.
    Maybe i try to find some waterproof case for the hi-fi only with a good electric protection directly from the main electric board.
    Tanx guys. :thumb:
  8. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    Put the speakers in condoms?
    Don't think the sound would be effected too much. Then again its not something I have tried.
    'doc
  9. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Probably only works if your speakers are pen1s-shaped :eeek:
    First place I would try for waterproof kit is a marine supplies company, like here.
  10. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    I know that Bose do an outdoor system, and these would be pretty easy to use for others.
  11. warchild
    30 Jan 2006
    Hey Flibblebot,
    i think you got the answer :idea: with that Marine site. Tanx a lot. :)
    Tanx again guys. :thumb:
  12. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Couple of problem areas,
    • Getting rid of heat from a 'waterproof' box. May need some fan-cooling through splash-proof ducting.
    • Mains voltage - safe way is to keep the transformer somewhere dry and run the secondary (low voltage) AC to the rectifier & amp. A bridged circuit will give max watts per volt.
    And remote control makes it a lot safer.
    You could just have a preamp near the pool, they only need a few volts and don't have heat problems.
  13. gbeeby
    gbeeby What's a Dremel?
    6 Dec 2005
    two words:
    Bin Liners
  14. warchild
    30 Jan 2006
    Hey cpemma,
    i think you've got the picture.
    Tanx a lot.
