Other Waterproof jackets
Discussion in 'General' started by legoman, 4 Apr 2017.
  1. legoman
    legoman breaker of things
    28 Feb 2010
    Any suggestions as I've no idea what I'm looking at, currently have a superdry article windcheater but the stitching is giving up an it just absorbs water.
    Looking to spent upto 80 at most
  2. Tangster
    23 May 2009
    Even in the worst weather my Altura jacket has never let me down. It's hig-vis, but I think they do normal colours as well.
    fuus likes this.
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    How about something like a Craghoppers Kiwi 3 in 1?
  4. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Check sportsdirect, they always have some some nice jackets/coats with ridiculous discounts... if you're lucky to find one that isn't an odd size. I nabbed a proper Helly Hansen winter rambling jacket for less than £40 last year.
    fuus likes this.
  5. legoman
    28 Feb 2010
    Is it any good? As said I had a Superdry so I know nothing!
    Had a nose on theres lots of branded ones I spotted a Salomon LA Cote Insulated an a couple of Helly Hanson ones. I'm thinking some kind of lining for warmth would be useful most of the time itll be used for work so ill just have a shirt underneath.
    fuus likes this.
  6. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    All I know is that i took one to Iceland in winter, stood at the bottom Seljalandsfoss Waterfall in minus 14 degrees - remained dry and warm.
    fuus likes this.
  7. Shirty
    18 Apr 1982
    I use a Dare2B ski jacket and it's lightweight and effectively weatherproof. Can be had for some bargain prices too.
    fuus likes this.
  8. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Go Goretex or go home.
    If you want cheapest-of-the-cheap, there are plentiful Army Surplus Goretex jackets available on ebay and elsewhere. They're not the height of fashion but they're sturdier than anything else you could get for the price, and you can get them in solid colours (not just DPM).
  9. Instagib
    Instagib Minimodder
    12 Mar 2010
    +1 for the craghopper. I've had one for around 2 years now and it's brilliant. Really warm, breathable and can be stripped down to a fleece + a lightweight waterproof jacket. Or you leave it as a whole as a warm waterproof. (hence the 3 in 1).
    The hood on the Craghopper is worth mentioning too; it's a oversized one with a peak to keep the rain out of your face and has lots of tabs/velcro to wrap your face up.
    I think I paid £99 at Go Outdoors.
  10. jrs77
    jrs77 Modder
    17 Feb 2006
  11. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    Marmot PreCip
  12. legoman
    28 Feb 2010
    Ill have to have a look at that Craghopper in the flesh so to speak.
    Had a nose in the surplus store, they have Helikon ECWCS Gen 2 jackets in grey an black brand new, Hydrostatic pressure of 10K which is just bonkers the guy there though said they are not the warmest of jackets as usually they would have carrier plates etc underneath which makes sense. The had some RN Foul weather jackets with lining one in my size but it was a class 2 with a huge stitched patch down the left side which the guy agreed would leak constantly, all the rest were XXL.
    The Helly is a bit too far out my price range annoyingly JRS, I had a look at the Dubliner and similar which don't look bad.
    Muchurios, I had a Precip ages ago but got rid as it was really sweaty they still the same?
  13. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    If you want a jacket that's completely waterproof and tough as old boots, look for a jacket designed for sailing. There's few environments more harsh than the sea - salt water, rain, wind, sunshine, cold nights etc.
  14. Xlog
    Xlog Minimodder
    16 Dec 2006
    While not really a jacket, you could also check out Helicon fleece with membrane, personally it serves me fine anywhere in 10..-15C range, up to ~20 if I'm stationary for long periods of time. Or just use a waterproof poncho :D.
    That helicon ECWCS jacket is intended to be used as soft shell, you need other layers for cold weather (the whole ECWCS concept).
  15. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
    don't worry about brands. Nowadays a lot of brands that used to be amazing for waterproof jackets (Berghaus, Jack Wolfskin, Peter Storm, Craghoppers, Gill, Helly Hanson, Henry Lloyd etc etc) have become trendy recently which has pushed the price up a crazy amount. This wouldn't be a problem, but most of them on the high street are for just jackets with the name on for people to walk around town with.
    If you want something to actually use for very wet weather or mountaineering etc, then check out some proper sailing jackets (you can search for the above brands, but make sure they are not high street shops). Alternatively, have a drive to somewhere that is a village around a mountain or by the sea. A lot of the time they have little shops that sell clothing for the weather they usually get. You can get some great bargains, but do be prepared to sometimes pay more as some are set up to pull down the pants of tourists.
