Modding waterwheel fan [mod aero7?]
Discussion in 'Modding' started by theagent, 20 Jun 2004.
  1. theagent
    theagent What's a Dremel?
    4 Nov 2003
    this is from my non-responsive thread under "extreme cooling"
    does anyone know where you can buy a waterwheel style fan like the aero7, but in a standard size? [such as 80 or 90mm square]. for me, this would be preferrable. getting rid of the blind-spot and having lots of air flow [90mm] could have great benefits. combining such a fan with the thermalright sp-97 could be circumstance for great cooling with low noise.
    email me back, jack
    but i have heard nothing, so i decided to post here and expand into the realm of "no such device."
    in the event that there exists no waterwheel style fan with a standard base size, i would consider modding my existing aero7 fan to fit a nicer heatsink. what results do you think one would find by attaching an aero7 [cited as available in 70x70x70mm size or 80x80x70mm, which i dont understand because i measured mine and it seemed to come out to be 65mm. i'll need to check again when i'm next at my dad's house.] to heatsinks such as the thermalright sp-97 or the swiftech fan with the massive amount of attached pins?
    http://www.thetechlounge.com/review.php?REVIEWDIR=aero_7
  2. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    You can buy the aero fan seperately if that's what you're after. Might be hard to get so have a look around.
  3. TMM
    TMM Modder
    12 Jan 2004
    yep, comes in 70mm and 80mm. but the actual fan is the same AFAIK, its only the mounting at the bottom thats a different size.
  4. theagent
    4 Nov 2003
    http://iocombo.com/product/showproduct.php?productid=09L6
    well, now on to the more important point
    what results do you think one could expect with a fan like this on a nice heatsink like the sp-97?
    it does do pretty well on its plain copper fin heatsink. i get temps at about 49C now that summer has hit [and i dont have air conditioning]. my barton 2500+ is overclocked to a 2800 currently, and my steady case temp recently is about 25C, though i cant say for sure... perhaps its closer to 29C [its hard to remember]
  5. theagent
    4 Nov 2003
  6. Darv
    Darv Bling!!
    12 Aug 2002
    How long is a peice of string? Seriously it will be different for everybody because of the countless factors that can affect it. Things like ambient temp, case airflow, case temp etc. The only way to find out for sure would be to try it and see.
  7. theagent
    4 Nov 2003
    yes... how long is a piece of string... *looks around*
    i'm not asking what temperature i would get, thats an idiotic question, but i'm asking for the opinion of the people, wondering if it you think it could be a powerful cooler
    undestand?
  8. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    get a delta fan.. they come in ordinary sizes, also you CAN buy aero7s in the 80mm format..
    but anyways..
    deltas have no "blind spot" as you put it
  9. theagent
    4 Nov 2003
    uhhh
    look at the delta fan here:
    http://www.bit-tech.net/article/55/
    how does that have no blind spot?
  10. theagent
    4 Nov 2003
    also about delta fans; well, they're not exactly silent
    http://www.sidewindercomputers.com/delhigper.html
  11. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    i think that thermaltake sell thoes kind of fans
  12. theagent
    4 Nov 2003
    1398342003 Ubermodder
    2 Sep 2002
  14. theagent
    4 Nov 2003
    cant really find any of them
    however i seemed to stumble across the aforementioned blowers by thermaltake
    http://thermaltake.com/coolers/comboCool/menu.htm
    i dont really like their site interface. i couldnt find those before no matter how hard i looked
  15. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    yeah they are the thermaltake ones i was talking about, i should have included a link hey
  16. malcs
    24 May 2003
    deltas are made so that they have no blind spot in the middle.. even though they look like they would have one.
    second... yes they are loud, but they are the best fan you could buy :)
  17. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    just a tip, that particualr style of fan is known ans a squirrel cage. That might help your searches.
