wavemaster classic
Discussion in 'Project Logs' started by axscpu, 7 Mar 2007.
  1. axscpu
    axscpu What's a Dremel?
    2 Jun 2006
    well the upper hole was placed a little of place so I can have access to the backpart of the mosfets without having to take the motherboard out.
    although looking again at the pictures I thinks I will need to grind a little bit more on the middle section.. will keep updating, thanks for the support guys
  2. TapperSwe
    TapperSwe What's a Dremel?
    20 Nov 2006
    It will be hard to straighten that hole up without loosing the 2 distancers closest to fan.
    Anyway good luck with your project.
  3. axscpu
    2 Jun 2006
    just got myself another mobo plate from a pratorian...... will measure four times cut once to avoid the mistakes done before... will post when I get the camera back :) :dremel:
  4. axscpu
    2 Jun 2006
    so I'm back with the little mod that i had going on, the thing is that I managed to get another backplate, so it was a clean start for me again.....
    anyway this is as far as i have done
    this is a side view of the case.
    and this is some etching I'm working on....
    now here is where I got stuck, it seems that the only place I can put the pump is below the hdd but the would mean a 180º turn of the tubes, so how would you guys do it????
    thanks in advance
  5. TapperSwe
    20 Nov 2006
    Now that looks much better .
    Regarding watercooling i cant help u because im a total noob at that :duh:
    Regards.
  6. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    the use of tygon tube and tube springs, or use two 90 degree elbow fittings, however it reduces the flow alot. so a long tube, and spring will do the trick.
  7. axscpu
    2 Jun 2006
    TapperSwe: thanks man comming from you that means alot.... nice fangrill you got going on!!!
    the thing is that I don't want to use 90º elbows, so the long hose and spring might be a option.....
  8. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    I'd say long hose & spring option. You dont want the 90 degree elbows. :).
  9. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
  10. axscpu
    2 Jun 2006
    yeah zhanqmaster that is exactly what I was looking for....
    I'll have to look for it in spain now!! :)
