Cooling WC block for P4 775
Discussion in 'Hardware' started by Isuo, 27 Mar 2005.
  1. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Ok, so basically I'm looking for a consumer priced WC block for P4 775, althought it would be nice to have the complete cooling system incuded.
    I'd like to have www addresses for good manufacturers that have resellers in europe.
    The whole system would be for overclocking purposes so it should have to be durable and trustable(have that word?).
    This takes me to my second question: Do the pumps break up esily, I mean in normal conditions.
    What else? Yeah, also your experiences of them if you have any.
    Thank you in advance.
    Isuo
  2. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I'd stick with 1/2" tubing and look no further than a Danger Den TDX, it's been one of the best all round performing/ flow rate blocks for as long as i can remember :D A few links for you sir:
    WaterCoolingShop.com
    Coolercases UK
    There's a brand new one here in the FS Forums aswell :D
  3. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    I say get the swiftech 6xxx series block, Its completly seled and there wont be a chance of it ever leaking, and also they make brackets for just about every socket from socket socket 423 to 775 for intel and socket a to socket 939 for amd.
    The flowrates are awsome on the block and it is all coper.
  4. Isuo
    13 Oct 2004
    Thanks!
    I think I'll go with the swiftech as it's about 10€ cheaper and I'm a bit short of cash right now.
    Btw. Have you god any good pumps to propose that are quite small?
  5. jaguarking11
    10 Dec 2003
    the swiftech 12v pumps are awsome, teh swiftech MCP350 Inline Pump is small, but the MCP650 Inline Pump is very powerfull. My buddy has one and it pushes allot of water, I also recomend geting a sunbeam rheobus to quieten the pump up, The rheobus will quieten it and also make the system run more eficiently by you being able to fine tune the pressure through the blocks.
  6. Isuo
    13 Oct 2004
    Thank you all.
    The only thing I have to see now is the fact that those are available in germany.
  7. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
  8. Isuo
    13 Oct 2004
    Sure it's nice. But the price (~70€) is a bit too much for my wallet. Hehe...
    EDIt: Or maybe it's not, but then I'd need to get the rest for under 100€
