Modding WC Question
Discussion in 'Modding' started by GigantoR, 26 Jan 2005.
  1. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    Is using a resevoir absolutely necessary? Say for instance I want to watercool a smaller case, using a barton 2500 OC'd. Can I just make the loop with Rad, pump and block? How would that affect performance?
  2. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Hi,
    I wouldn't say it's absolutely necessary, but it makes life ALOT easyer, when you need to top up the system.
    Proformace wise; I'd say it wouldn't effect it alot, but it will to some extent.
    Rob.
  3. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Could make it quite difficult and messy to fill, as well.
  4. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    It is alot easier ::
    1. It's easier for filling
    2. It let's the air go to the highest point in the system, good for bleeding
    3. They look great :D
  5. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    What I Have seen done is ... instead of a res... just a length of tube that goes up to the top of the case (from a T piece in the loop) and ends on one of those fill points. that does work.. but you would have to keep an eye on it a bit more as the bubbles work out.
    You can do it.
    The res also acts as somewhere for the water to sit for a bit and calm down a bit which apparently is good for it. lazy water!
    -J
  6. BlackDiamond
    BlackDiamond What's a Dremel?
    7 Sep 2004
    is it a must? no
    does it make filling/bleeding easier? yes
    I have just built my first WC system and I didn't have room for a res, so I put a T-line and it was not as much hassle as I thought it would be.
