Cooling wc setup help
Discussion in 'Hardware' started by dan-ere-07, 2 Feb 2008.
  1. dan-ere-07
    dan-ere-07 New Member
    29 Mar 2007
  2. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    As long as the pump is pulling the water from the res then the order of the components in the loop wont matter, its best to connect the loop up in the easiest way. As for the rad, a single Thermochill PA 120.3 will be enougth to keep the cpu and gfx cool.
  3. dan-ere-07
    29 Mar 2007
    thanks for the help
    what would be a good pump to use?
  4. FragileSocks
    FragileSocks New Member
    25 Nov 2007
    Swiftech MCP655-B 12 VDC Pump.
    I have one of these, but the variable pump speed version. I use mine on full all the time and can't here it running so for the price difference I would go for this one.
  5. Guest-23315
    Guest-23315 Guest
    a Laing DDC with an Alphacool, Petra's or EK aftermaket top. I allways go from pump, then rad, then blocks ect.
    Otherwise looks good!
  6. dan-ere-07
    29 Mar 2007
    would a Thermochill PA 120.2 be ok to cool these 2?
  7. Guest-23315
    Guest-23315 Guest
    Easily, yes.
  8. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Yeah, you'd be fine with a 120.2. I'm cooling an OCed e6850 and an 8800GTS (G80) on a 120.3, and it's overkill. You'll be fine with that.
  9. LVMike
    LVMike New Member
    11 Aug 2004
    I agree with the pa120.2 with some yates fans you will get good cooling and low noise.
  10. dan-ere-07
    29 Mar 2007
