Cooling WC temps tell me all !
Discussion in 'Hardware' started by Jagdwolf, 22 Jan 2007.
  1. Jagdwolf
    Jagdwolf What's a Dremel?
    13 Dec 2006
    Hey all I have a water cooled system. CPU GPU north south and physx card. its all cooled by a danger den system. can everyone share what temps they are getting on the following please. just so i know where I stand. and this is just at no load.
    CPU
    GPU
    North
    South
    extra stuff.
    Im flying:
    Nvidia 830 CM Evolution case
    Nvidia 850 CM PSU
    EVGA 680i mb
    BFG GTX8800 Water cooled from BFG via Danger Den
    QX6700 quad core WC w/Danger Den 775 block
    North and south bridge with the Danger Den 680i block (modified on the south bridge to fit the danged long 8800 card.
    BFG PhysX card with a Maze 5 block
    Black ice 240 extreme radiator
    D5 12v pump.
    and the other junk
    WD Raptor 150 sata
    WD 160 7200 sata
    Plextor dvd burner etc sata
    floppy ( some things never die)
    2g pc8500 corsair dominator ram with cooling fan.
    Please tell me what you all are getting
    thanks
    Wolf
    CPU 41
    GPU 49
    system (northbridge) 32
  2. samkiller42
    25 Apr 2006
    Despite the fact i have a different setup with different gear, i shall tell you my temps for what i have cooled, currently:
    Core 2 Duo E6700 idle: 26C
    XFX 7800GTX idle: 33C
    Core 2 is under a storm 4 and the xfx is under a cool-matic block, and i do have 5*120mm (2*120 and 3*120mm)
    Sam
  3. Nexxo
    23 Oct 2001
    Dual Opteron 250: temps of 42C and 45C respectively (my Radeon 9800Pro does not report temps). All on a single BIX. :D
    And my NB? Passively aircooled by its original heatsink: 30C. :D
  4. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    AM2 4200X2 EE. cooled by a DD TDX on single 120mm black ice pro rad.
    20C Idle to 30C Load
  5. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    Both watercooled and in separate loops
    CPU under Storm, D5 Pump, TC 120.3 Rad
    c2d e6600 @ 3.4Ghz: 20c idle
    GPU under EK X1900 block, D5 Pump and PA160 rad
    X1900XTX @ 700/800: 41c
  6. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    Wish i was still into watercooling :(
    e6600 32c idel 45load zalman 7700cu :D
  7. samkiller42
    25 Apr 2006
    Ha ha, let brooxy buy all your old gear :D
    Sam
  8. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    You called....it's highly tempting, sam, if you wanna keep hold of the block for the 7800 for a bit, just while I work out what i'm doing...
  9. clocker
    clocker Shovel Ready
    21 Dec 2003
    Sorry guys, but none of the posted temps mean anything without the inclusion of ambient temps.
    The deltaT is more informative than just a naked number.
    For example...
    This would lead one to assume that I have the most effective waterloop of the bunch if you just did a straight comparison, no?
