Cooling WC tubing advice
Discussion in 'Hardware' started by Andy Mc, 10 Feb 2009.
  1. Andy Mc
    Andy Mc Modder
    23 May 2002
    Hey,
    Looking to replace the tubing in my wc setup (swiftech h2o-220 compact) from the standard black neoprene to something clear.
    Any advice on what to go for and what to avoid? Also does any one know what size tubing I would need? as I don't have the packaging where I am at present to check.
  2. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    It takes 3/8" tubing. Good tubing includes Primochill Pro LRT, Tygon 3603, or TFC tubing are all highly recommended.
  3. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    Can't fault Tygon. It bends well, doesn't kink easily, its non-porous and doesn't stain. Its just a bit pricier than the rest, but not massively so.
  4. Krikkit
    21 Jan 2003
    I'm using Tygon R3603 atm, very good tubing.
    I certainly won't buy anything other than Tygon again, I'm thoroughly satisfied.
  5. Andy Mc
    Andy Mc Modder
    23 May 2002
    Well Tygon it is then I think. Any advice on the best place to pick it up in 3/8" then?
  6. severedhead
    19 Dec 2002
