Case Mod - In Progress WC'd Antec 1200 i7 & GTX295 rig dual rads *FINISHED + FINAL PICS/RESULTS*
Discussion in 'Project Logs' started by coolamasta, 16 Jan 2010.
  1. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Hi all, been trying to get around to properly cooling my Antec 1200 with i7 & GTX295 but with one thing and another I've only just got around to starting it off!
    Full Spec of hardware:
    • Antec 1200 full tower case
    • Asus P6T Deluxe Motherboard
    • Intel Core i7 920 D0 CPU @ 4ghz
    • OCZ Reaper PC3-12800 1600MHz Ram 7-7-7-24
    • XFX Nvidia GTX295 Graphics Card
    • Asus Xonar DX Soundcard
    • Gigabyte Odin 800w Modular PSU
    WC spec list:
    • EK Spin reservoir
    • Swiftech 18w DDC pump
    • XSPC DDC Pump Acrylic Top V3
    • 2 x Phobya G-Changer 240 Radiators
    • EK Supreme Acetal CPU Water block
    • AquaComputer AquagraFX GTX295 Water block
    • 1/2" ID 3/4" XSPX tubing throughout
    • Feser Compression fittings throughout
    • 2 x Yate Loon D12SM-12D 120mm Fans for front rad
    • 2 x Kaze-Jyuni Slipstream 120mm Fans for top rad
    Yesterday I went about stripping the case and fitting the Rads in, wasn't sure where to put them but decided on one in the front and one up top as there was so much free space up there!
    I have spaced the top rad slightly of the Antec Big-Boy fan to create a better gap between them which should help in exhausting the hot air. I used motherboard brass fittings to space out the rad and it worked well, just had to slightly enlarge the holes on the rad to take them.
    Just waiting for a few more parts to arrive then I can continue the build, for now here are some of the strip down and rad fitting...
    Rig as it was running with side off
    Close up of guts
    Motherboard etc removed
    Rig in temporary position so I can still use it & game!
    Pics of rads & a Yate Loon fans
    Yate Loon left, Kaze Jyuni right
    Rad held in place by 4 small L-shaped Brackets
    Checking clearances for front fans before fixing in rad
    All screwed up into place with brackets & fans
    Top pic looking down on rad & fan sandwich, notice the brackets
    Motherboard brass stand-offs fixed to top rad
    Holding top rad into place to mark screw holes
    Top rad fitted and lid about to go back on
    Looking up at top fan with Kaze Jyuni's fitted
    Front shot of the top rad & fans
    240mm Rad just about fits up there, literally 2mm free space!
    Shot of fan testing, Kaze's are loud and move loads of air but they will be on a fan controller anyway, the Yate Loons hardly make a noise and with all Antec fans on low its soooo much quieter than before, just hope all this keeps the temps good!
    Quick front shot showing EK res etc, ready for part 2!
    Any comments good or bad? Im just hoping 2 x dual rads are good enough to cool the over clocked i7 & 295 :worried:
    Cheers all,
    Rob. :thumb:
  2. andrew8200m
    andrew8200m Modder
    4 May 2009
    Those rads certainly are up to the job and that's exactly how I had mine set up but I used mcp220 rads and 4x ds12h yates for the front rad and 2x ds12h fans in the roof running at 7v ish.
    Good work! Never made a log of mine, should have I suppose.
    Oddly identicle kit that came out of mine bar the 295 tht was a single pcb and the ram that was the 1866mhz cl9 stuff.
    Andy
  3. TheAbyssDragon
    TheAbyssDragon Gafgarion
    8 Dec 2005
  4. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
  5. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    Yay for dual antec 1200 loops! Plus you've mounted them in the same place. Looking good, where did you get the 'L' brackets from? Need a pair for mine, lazily propping them up won't cut it for me lol.
    Where you planning on putting the pump? There isn't a fat lot of space left with the front occupied by the rad and fans.
  6. coolamasta
    26 Apr 2009
    Yeah I knew about them but being aluminium I didnt bother as I dont want issues running different metals in my loop, heard bad things!
    Haha cheers bud, L shape brackets just come from B&Q, like 50p each or something, had them sat about from a previous project and it just so happened to be exactly the right size so I needed to didn't have to make different holes in them!
    I have an Idea for the pump but cant test my theory until the final parts arrive, it will be on show just hope there is enough space for the tubing though as im using 3/4" :worried:
  7. coolamasta
    26 Apr 2009
    Couple of quick pics from today, didn't have much time but managed to spare half an hour to cut down one of the hard drive mounts/caddies as it wouldn't go in due to hitting the end tanks. With a quick chop theres plenty of space now to access the front rad pipes meaning I can still use 2 x HDD's which are cooled :)
    After the hacksaw had been out, normal one on right
    Fitted inside with 2 HDD's leaving a nice bit of room for rad piping
    Outside of case looking normal again :D
  8. coolamasta
    26 Apr 2009
    Got the bulk of the work done over last couple of days, couldn't mount the pump where I originally wanted so had to settle for the bottom of the case but shouldn't cause any problems :)
    Here ya go:
    Rest of the Watercooling Parts
    G1/4 LED holders with UV LED's fitted into EK Reservoir
    18w DDC Pump mounted on rubber feet
    Motherboard & PSU mounted with EK Supreme CPU waterblock
    Starting to pipe it up with red UV coils
    Stripped GTX295 (was slightly scary stripping it knowing warranty is out the window)
    GTX295 PCB's all de-greased & de-dusted
    New Thermal paste & memory pads ready to fit to waterblock
    Both GTX295 boards carefully fitted to Waterblock
    Another side shot of GTX295 all waterblock'd up!
  9. woodss
    woodss Yes Louis Wu
    19 Jan 2010
    Ridiculously nice choices!
  10. andrew8200m
    andrew8200m Modder
    4 May 2009
    This is coming along nicely mate!
    Andy
  11. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    didnt realise that antec was so big... Its rather roomy in there isnt it
  12. shakka65
    shakka65 What's a Dremel?
    17 Jan 2010
    Great looking mod so far.
  13. coolamasta
    26 Apr 2009
    Thanks for the positive comments people :thumb:
    Has a couple of hours free last night so done a bit more, I managed to sleeve the case header cables and pump and also finished the plumbing, leaving the filling up and testing to tonight wooooop! :D
    Sleeve'd Front Leds/Switches/USB & Audio
    GTX295 in place and all piping connected ready to go!
    Angle shot of piping
  14. coolamasta
    26 Apr 2009
    Woooooooooop! Its alive :rock: Fully working, no leaking and soooo much quieter! :D:D:D Didn't have time to stress it last night but idle temps are between 32-35 degrees on the CPU @ 4ghz and both the GTX 295 cores :clap: :naughty:
    Some more pics -
    Testing water loop without powering Mobo
    EK Reservoir filled but not running
    Whole machine fired up and running happily!
    Funky shot 1
    Funky shot 2
    Case shot with it fully running, looks pretty much standard from the outside ;)
  15. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Nice work. :thumb:
    Stress temps would be interesting.
  16. DeadP1xels
    30 Nov 2009
    sweet build man
  17. coolamasta
    26 Apr 2009
    Some more funky shots of it all working, just playing with the overclocks now but seem to be running at great temps so far and only other thing I need to do is add in the 2 x cold cathodes to finish it off :)
    perplekks45 likes this.
  18. mrbungle
    20 Sep 2004
    Very nice :)
    Think I will buy this case for the space though I still think 130 quid is a bit too much for what it is.
  19. bagman
    bagman Minimodder
    18 Apr 2009
    some very nice final shots there
  20. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Where can you buy things like that cable sleeve? Looks awesome!
