Education We Like to Ride Bicycles
Discussion in 'General' started by RTT, 8 May 2008.
  1. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    I'm writing a report on bike selection.
    Your input is appreciated.
    For price of your bike, enter approximate dollar amount.
    Thanks
    Survey
  2. TheDodoKiller
    TheDodoKiller Minimodder
    23 Oct 2011
    Your survey is difficult because I only really ride in the summer. I may ride around 150 miles a week, but only between sorta April and October.
    What should I put?
  3. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    Done. Although I only cycle commute in term times so about 35 weeks a year.
  4. llamafur
    27 Jul 2009
    Just go for the weeks you ride.
  5. legoman
    legoman breaker of things
    28 Feb 2010
    Some basic hydros to replace the mechanical front on my work commuter, took it for a quick run defiantly an improvement. 203mm disc and surprisingly braided lines as well.
  6. JoshH
    JoshH What's a Dremel?
    19 May 2012
    Here's a quick pic of my giant Defy
  7. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    Yaaay bike twins. Just cleaning mine atm: [​IMG]
    Also it's a friend's birthday soon so we're rebuilding her bike and spraying it fluorescent pink :p
    The bike:
    Stripping the frame
    Sanding the original paint off (by hand... takes ages)
  8. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    Am going to build my cove this week :) Just waiting on some parts but should be out on it at the weekend and I am immensely excited about this!
  9. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Could do with some help/ideas on clothing.
    I don't currently do much biking (none really), but am going to Scotland in two weeks, and we'll probably do a days biking.
    I've got both a road and Mtb and want to start riding more.
    All my current lower half clothing is too small really.
    What I used to wear was
    Mtb:
    padded shorts
    tracksters (tight things)
    camo trousers cut down to 3/4
    Road:
    padded shorts
    tracksters ontop if it was cool
    For mtb'ing, they weren't great as they were getting a bit small, so constricted around the waist a bit, and I suppose added some weight too as the camo stuff is pretty heavy duty.
    And now I'm looking at what to get to replace it all. And I'm stuck, :D
    Can't decide on what I want, or really need.
    So, what do you recommend for light'ish XC biking trousers wise?
  10. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    For inexpensive and versatile I have used both of the following:
    Endura Humvees 3/4 length trousers
    Endura MT500 Spay baggy shorts
    The humvees are a nice length, light weight and are a good compromise in the Scottish conditions. The MT500's have a waterproof crotch and back panel but the rest it normal breathable fabric so again they are a good compromise between comfort and practicality.
    Where abouts are you going to be in Scotland?
  11. RevDarny
    RevDarny Minimodder
    27 Oct 2011
    I've always found Endura gear pretty good and it's doesn't break the bank.
    These have been pretty good. You can also buy another pair of liners then you can reuse the shorts the next day if they're covered in dirt with a fresh pair of liners.
  12. Lance
    Lance Ender of discussions.
    6 May 2010
    I may have been unlucky but I too have a pair of (road) endura shorts and the stitching on them is falling apart and they seem a bit cheaply made, but I may have been unlucky.
    Also the reports on the reflective road trousers all seem to say that the reflective part comes off after a few washes.
  13. Margo Baggins
    28 May 2010
    on my road bike, I wear a tracksuit and gloves as I don't really like alot of bike clothing - I have different gloves depending what the weather is like (i ride about 70 miles a week on my road bike). I'm not too fussy about the rest of my body except my hands, I wear a helmet also.
    When I'm out on the mountain bike I normally wear some mtb specific trousers or shorts. I have a couple of pairs of sombrio trousers that were quite expensive, but haven't lasted at all, so I wouldn't advise those - I think I have got about 4 or 5 rides out of each pair before the crotch area ripped and some of the panel stitching has come undone, that's quite hard trail riding though but still I would of hoped for them to last longer. I got a really expensive pair of fox shorts that have lasted well and fit well and had a nice padded liner that I can wear with any of my other garments. tops, I just wear t-shirts, though I have ordered a jersey with 3/4 length sleves, as I am finding most weekends im too hot in a jumper and too cold in a tee, so this is a compromise layer that I will wear over a tee.
    Alot of my friends ride in Troy lee designs gear. I am going to stick to fox and troy lee for off road - as my friends gear all seems to have lasted a long time, and my fox gear has lasted well. Spendy - but I think it's worth it. And last years gear can often be picked up in sales for half price - and I don't give a damn what year its from, function over form for me!
  14. Cerberus90
    23 Apr 2009
    Aviemore, we've got a timeshare in Dalfaber, so have been going up there every year for the last god knows how long, :D.
    Thanks for the advice people.
    I should have mentioned I'm at the budget end really, as the stuff may end up not getting used as much as it should.
    I'd seen the endura stuff on CRC, but couldn't decide what I'd need.
    Probably get a pair of the Humvee 3/4, as I imagine most of my riding away from scotland will be in the warmer weather in the summer, where 3/4s would be fine on there own and trousers probably too hot.
    Might see what Bothy bikes have got when I get up there, and the shop at Laggan seemed pretty good the last time we went there.
  15. Lance
    6 May 2010
    Why is it that mountain bikers wear baggy shorts over Lycra like roadies? Doesn't it make more sense with normal cycle shorts?
  16. Margo Baggins
    28 May 2010
    I have got no lycra roadies! But some shorts come with padded liners that are not too disimilar to lycra roadies. Though they are very much an under layer! Baggies tend to have no padding, a padded liner is nice.
  17. legoman
    28 Feb 2010
    Also with the Humvees you get a liner which is a lycra inner short that clips to the outer short it has a padded crotch too.
    Bonus of the liner is you can move it between shorts I ripped my humvees after a large tumble, picked up a pair of Endura Zyme shorts an the liner went straight in. Have to say I prefer the Zymes over the Humvees mainly as its a tougher heavier fabric.
    Also tip from someone whos been up there, you may want some leg protections mainly because the plants overhanging the trails seem to be rather spikey
  18. Digi
    Digi The not-so-funny Cockney
    23 Nov 2009
    Erm.. wear whatever's comfortable? I cycle daily in everything from work trousers to jeans.
    If you're on a budget just get a pair of old whatevers out of the wardrobe and use those. :confused:
  19. Cerberus90
    23 Apr 2009
    Trouble is I don't have a pair of old whatevers that would be comfortable for biking. :D
    What plants are spiky legoman?
    I've got 661 shin and knee guards, but don't wear them for anything but DH as they're too awkward.
    Never had a problem so far with flora. It's usually my pedals that end up cutting my shins up, or our stupidity that ends up with us losing momentum in the middle of a river ford and having to put a foot down, :D.
    Although pretty much everytime we do the same run, from aviemore to Loch en Eilen then on to Loch Einich, which are quite wide trails. Want to try something else this year though as it's got boring doing the same ride every year, and usually not managing to get to the end, :D
  20. JoshH
    19 May 2012
    An sweet! How do you find it?
