Education We Like to Ride Bicycles
Discussion in 'General' started by RTT, 8 May 2008.
  1. fix-the-spade
    fix-the-spade Well-Known Member
    4 Jul 2011
    Lycra makes great sense until you crash, or it's gets ripped clean off in the brambles.
    Lycra under baggies is best, there's no substitute for rip-stop material when your arse meets gravel.
  2. Lance
    Lance Ender of discussions.
    6 May 2010
    That makes a lot of sense when you put it like that. Hadn't really thought about it that way before.
  3. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    I did a weeks mountain biking there last year. Bothy Bikes is great but the shop at Laggan only had about 3 things in it and it was so dark you couldn't see anything. I would highly recommend the Speyside maps collection from Trailmaps. You can get them online before you go or from either Bothy bikes or Mikes bikes in Aviemore. Just outside of Aviemore is the Inshriach nursery and cake shop which probably sells the most amazing cakes in the world. It is definetly worth a visit! We ran out of time to do it but at £20 per person the Bike Cairngorm trip looked pretty good.
  4. RevDarny
    RevDarny Member
    27 Oct 2011
    It's partly a fashion thing as well
  5. woof82
    woof82 New Member
    18 Jul 2005
    Awesome, I love it. And I overtake people on carbon bikes so I'm not complaining :)
    My next purchase will probably be a new saddle, I think I have a wide bum.
    Eventually I might get some new wheels and tyres since the stock ones are quite heavy.
  6. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Thanks for that.
    Bike Cairngorm certainly does look cool.
    If there's snow, I'm hoping to do some snowboarding, which'll probably mean I won't be doing anything else after that as I won't be able to move, :D
  7. Jake123456
    Jake123456 Surprise!
    25 Jan 2011
    I'm looking at building my own bike...Can anyone point me in the right direction where I can buy all my parts from please? :D
  8. Da_Rude_Baboon
    28 Mar 2002
    What type of bike are you wanting to build?
  9. steveo_mcg
    steveo_mcg New Member
    26 May 2005
    Your local bike shop, chainreaction, rose bikes, wiggle the list is fairly extensive. What do you want to build, how much do you want to spend, why not buy off the peg?
  10. Jake123456
    25 Jan 2011
    Road Bike, I'm not too sure of spending...But I have a limit of around £700?..
    And I like just building things and using them, gives me that...Self satisfaction...:)
  11. Lance
    6 May 2010
    That's expensive way of doing things.
    I know what you mean about building things, but I would seriously consider buying one, and having a good old fashioned tinker.
  12. steveo_mcg
    26 May 2005
    As the man says buy a whole one and fiddle, you'll never get a better price for the groupset etc than the big manufacturers. But if you do want to go down that road, I'd get a used road bike, if its been well used the drive train will be shot but probably usable so you can get on the road and rebuild to your hearts content.
  13. woof82
    woof82 New Member
    18 Jul 2005
    If you can find a vintage steel frame bike in a classified ad you might be able to get a good price on a worn but otherwise good bike. Then you can do your tinkering replacing all the worn parts, refurbishing it, customising, upgrading it etc.
    Then you'll have a nice bike that you rebuilt and customised yourself.
    If you do this you will need various specialist tools (Chain tool, bottom bracket tool, cassette tool, chain whip, torque wrench, pedal tool, bike grease, headset setting tool, headset removing tool) along with the usual tools (allen keys, spanners, pliers, wire cutters, screw drivers). Admittedly you can set and remove headsets with a mallet and a metal tube if you're careful. Just don't tell Malvolio.
    Of course if you want a performance machine you should just buy a bike. Specialized, Trek and Giant all do entry level road bikes. Personally I recommend Giant, a Defy 3 retails at £699. Also check out Specialized allez range.
    Bonus of buying on is you can go to a shop have a look around and see what you like, get sized up etc. Most places will let you take one for a quick ride too so you can see how you like it. They also usually offer a couple of free services, guarantees etc.
  14. M_D_K
    M_D_K Active Member
    3 Apr 2002
  15. Jake123456
    25 Jan 2011
    Thanks for the advice guys! That Defy looks pretty nice...Any other Road Bikes which I could look at? :)
  16. RevDarny
    RevDarny Member
    27 Oct 2011
    Specialized Allez, like the Giant Defy, there are several build specifications ranging in price from £500 to £1000. You could buy second hand. The pre 2013 Allez had a carbon fork from the sport spec upwards. Now they all have an aluminum fork for 2013, which in my opinion is a shame
    You could take a look at www.ribblecycles.co.uk. They're only online so you'd need to do some measuring up first which there is a guide for. You can't test ride the bike, which is not always a great thing. But the bike builder allows you to spec the bike you want and £1000 gets you entry to a full carbon frame. Though the carbon build won't be the same spec carbon as a £4000 carbon bike would be. Their Sportive Bianco has had some great reviews.
    The Giant Defy is a very good bike for the money and worth a ride.
  17. steveo_mcg
    26 May 2005
    There was some issues with the Allez fork, a buddy of mine has been without a bike for nearly 5 months now waiting on the product recall to be sorted out...
  18. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    No it's sold out :( Which is a shame as it's not far from me at all.
  19. Lance
    6 May 2010
    I have the 2013 sport in black and it has a carbon fork.
    I've only really ridden in twice since I got it last month because a) rubbish weather and b) other commitments but I've really enjoyed it so far.
    Also just from a vanity point, the matt black colour is beautiful, gets so many comments.
    Regarding the issue on the forks: it seems to be the older models.
  20. Jake123456
    25 Jan 2011
