Education We Like to Ride Bicycles
Discussion in 'General' started by RTT, 8 May 2008.
  1. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    This may help with the cassette wear, you can tell by a visual check usually signs of hooking - might not look like much but if compared to a brand new cassette its easier to see the difference - http://www.bikeradar.com/gear/article/workshop-transmission-wear-20788/
    I got something like this for an 'everything' toolkit - http://www.chainreactioncycles.com/x-tools-bike-tool-kit-37-piece/rp-prod55963. There was a few more specialist bits I needed over the years and when I did wear out tools I bought park tools for the most used ones. Worth keeping an eye on the online bike retailers as usually someone has an offer on a tool kit
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    That is fairly similar to the set I got from CRC, and likewise, I then expanded with a few more specialist bits, and then also replaced worn out tools with park tools. I think I managed to get my tool kit in a sale for about 35 quid.
  3. Lance
    Lance Ender of discussions.
    6 May 2010
    I have this tool kit and its pretty good.
    I did also buy myself a good set of cable cutters which are brilliant.
    As above I'd buy a kit and then upgrade to Park Tools as you wear stuff out as you'll work out that way what you're going to need better quality of.
    If you can get one of the Aldi work stands a good workstand makes a major difference. If you can't buy one maybe borrow one. I have the park tools one, but I'd say its more than you'd want to spend. The benefit is that you can spin the wheels and have access to the handlebars to set everything up nicely.
  4. Porkins' Wingman
    Porkins' Wingman Can't touch this
    23 Feb 2008
    Cheers guys, that's some great material for me to be getting on with. Thanks for the link to the transmission wear article, dynamis :thumb:
  5. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    If you guys were building/buying now would you go 26, 27.5 or a 29er.
  6. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    Depends on the type of riding its for and your height.
    Sent from my iPad using Tapatalk
  7. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    There's a deep, deep question.
    My next bike will probably be a 650b frame, but with 26in wheels on it, because that's a viable option too.
  8. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    I'm 6ft3
  9. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    650b. I'm 6'6", riding a L Whyte G150. The 650b wheel is brilliant for AM riding. Still retains the manoeuvrability of the 26" wheel but can the roll over of a 29".
    29ers are starting to look less like a clown bike now as frame geometry is beginning to catch up. What sort of riding are you planning on using it for?
    Sent from my GT-I9505 using Tapatalk
  10. teacherboy
    teacherboy Part Carbon/Nylon/Bovine
    29 Jan 2012
    Just signed up for this:
    Somerset Levels 48 mile ride
    Anyone else having a bash at it??
    And as i've been open about my heart surgery on here - i'd be really grateful for any donations made.
    Donate here
    :thumb:
  11. fix-the-spade
    4 Jul 2011
    You have 1 donation.
    On a similar note, will anyone be at the 'Ard Rock Enduro this coming weekend?
    Lookout for the very slow man on a Cotic.
    teacherboy likes this.
  12. Cookie Monster
    27 Aug 2003
    You have a 2nd donation.
    What Cotic do you ride? There's a Roadrat on Ebay at the moment (ends in an hour), I'm very tempted with to swap my Forme Calver over too just so I can add discs to my Cyclocross bike. But the geometry is something like 50mm longer and my Calver is so comfortable, I just can't make myself buy it.
    On top of that it's guatenteed to me heavier with it being steel. Then I'd need to spend extra cash on disc wheels and discs. Though banging on a Hope V-Twin is a great option.
  13. teacherboy
    29 Jan 2012
    Thank you very very much :thumb::thumb:
    Training ride today - 20 miles = 1hr 25 mins, much more undulating course around Yeovil (90 meter up and down at least) than the real course around Glastonbury so should be on for around 3.5 hours for the 48 miles if training goes as I plan :geek:
    This is on a 26" hardtail mountain bike rather than road bike - mostly due to the fact that ...... I don't have a road bike :duh:
  14. fix-the-spade
    4 Jul 2011
    Rocket FS bike, I like it, nicely made, dead reliable, but it's a tank and slightly too small.
    New bike next year :D, as for the Road rat I know nothing about them, but the finish on my Rocket is great.
  15. Cookie Monster
    27 Aug 2003
    I ended up not getting it, though it only went for £85 + £15 P&P. I do fancy something new though. I've been contemplating giving my Giant XTC to my bro and getting either an Giant Anthem or Trance 27.5. See what's at the trade show in 2 weeks and have I think.
  16. teacherboy
    29 Jan 2012
    One for the more technical bods.
    I'd like to replace my xt m770 11-32 cassette with an ultegra cs-6500 11-25 (or thereabouts) to narrow the gearing on my hardtail. I'll still be running triple rings on the front for the time being - can i keep my xt m772 sgs rear mech with the cs-6500 cassette or will i need to purchase a medium gs cage rear mech??
    Research thus far indicates i can keep my existing mech, just swap the cassettes and bash on a new chain - can anyone confirm this is the case :dremel:
  17. Cookie Monster
    27 Aug 2003
    Yeah you should be okay. Once you fit the new cassette, be sure to reset your gears and stop screws to make sure the chain isn't coming off and ripping your wheel to bits.
    The deal with the cage sizing is depending on your chainset sizing. A longer cage will give you more chain because of the increased cage length, enabling you to use your larger rings.
    Edit: ripped from here
    Short cage = Normal double chainset and rear gears upto about 27T big sprocket.
    Medium cage = Campag' say for "Compact chainsets"? ie 50/34T and Shimano advise 27T rear max'.
    Long cage = Triple chainset and sprocket again upto 27,ish for the road range of dérailleurs.
  18. mars-bar-man
    17 Apr 2009
    I went to Afan a few days ago, and I died, couldn't get the fluids into me quick enough. Very tough day riding.
    Here's a shite little video I threw together of parts of it:
    http://vimeo.com/101569462
    And now for a generic bike photo:
    Also decided to go 1x10, so I went with a narrow-wide chain ring and a chain guide with a bash guard as well:
    It's a 32t chainring, the stock was a 36-22 2x10 set, I rarely used the granny ring except on all but the largest climbs, so hopefully my endurance should jump up with this as well! Looking forward to give a try out.
  19. fix-the-spade
    4 Jul 2011
    The looks like you're using a bashguard chainguide, without a guard or a new top plate it's not going to do much for your chain!
    Anyway, I went the other way last month, from 32t only to 26/36 on the front, my legs just didn't want to play ball.
  20. teacherboy
    29 Jan 2012
    First ever set of spd shoes, pedals and cleats purchased and (eventually) installed and tested today. Non-drive side pedal refused to come off and broke....
    1 x 6mm hex key (snapped after being hit with a hammer to try and undo the pedal)
    2 x 7mm adaptors for a drill (torque overcame the glue in the adaptor and it span while the 6mm hex key stayed in one place)
    also caused serious cosmetic damage to my pedal spanner and a small ouch to my thumb where i missed the hex key with the hammer .......
    Eventually defeated it by blowtorch to heat pedal thread/crank to loosen thread a touch and then melted the plastic bearing shroud off, tightened my bahco 9031 slim jaw adjustable spanner onto the remains of the semi-rounded pedal nut and ................... smashing the shibobble out of it with a hammer.
    On teh plus side - I can ride the bike with the spd pedals and can safely unclip with either leg and clip in easily too :thumb:
