Education We Like to Ride Bicycles
Discussion in 'General' started by RTT, 8 May 2008.
  1. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    Bit of Cyclocross fun last night, with this 28.2mph :D
  2. BennieboyUK
    24 Nov 2010
    My lad (6) taking on some climbs and descents at Swinley Forest.
  3. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    Glad the Lycra perverts are shut in for mountain-bikers to enjoy the weather.
  4. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    We're still about: there's no such thing as the wrong weather, only the wrong gear.
  5. legoman
    legoman breaker of things
    28 Feb 2010
    Exactly, I prefer riding in the cold, an the wet doesn't phase me either on road or mountain bik
  6. legoman
    28 Feb 2010
    Replaced the bars as they were doing my head in, cable channels were cracking an its just where you put your hands, my own fault for doing cable runs too short. Also gone slightly more narrow on the bars after having my ICS measured. Decided on some fun bar tape as well.
  7. Weekly_Estimate
    Weekly_Estimate Gives credit where its due
    1 Feb 2010
  8. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Giant are the largest bicycle manufacturer on the planet by quite a margin. They're basically the Toyota of bicycles, nothing exciting (God forbid!) but they'll roll around and around unexcitingly forever.
  9. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Unless your name is Danny Hart :thumb:
    Have a 2010 Devinci Hectik that has recently recieved a brand new powdercoat job, new decals, all new bearings and hardware, freshly installed BB, new (but old) shock and TFTuned mounting kit... Shame I'm not gonna build it up into a full bike, its certainly been a project!
  10. Vault-Tec
    30 Aug 2015
    Getting there... Even though the powder coater masked off the brake mounts he didn't do them all the way so I have to scrape with a blade. Very time consuming and a PITA.
  11. fix-the-spade
    4 Jul 2011
    I would argue Danny STAY ON YOUR BIKE Hart is the exciting part of the equation, given his performance on Mondraker lately maybe the Glory was somehow making him less exciting, an excitement vampire if you will.
  12. Wakka
    23 Feb 2017
    Restoration of the Devinci is almost complete.
    It's been stripped down, sand blasted, given a lovely semi-gloss powder coating, had all new roller needle bearings fitted, freshly serviced Monarch, new shock hardware, new XT BB, new pivot bolts, custom decals. Almost as fresh as the day it rolled out the hand-made Canadian factory.
    Shame i'm never going to be able to ride it :(
  13. Weekly_Estimate
    1 Feb 2010
    Put a new chain on the giant and now no matter how much i play with the L/H screws it doesn’t want to behave :/
  14. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    It is best to replace the chain and sprockets together. The new chain won't mesh properly with the old sprockets, especially if they are well used (they don't have to look very worn).
  15. legoman
    28 Feb 2010
    Very much this, chances are the teeth are sharktoothed, I noticed this when I put a new chain on, it was slipping an mis shifting every gear, new cassette, worked like a dream.
    Did you do the chain the same number of links? An also check some (not many) chains are directional.
  16. Jipa
    5 Feb 2004
    My new ride. Well obviously not "new", but newer than the older one :)
    The Ice Spikers are brutal. I had no idea there could ever be so much traction on ice.
  17. Weekly_Estimate
    1 Feb 2010
    Next stop a new cassette then!
    Counted the links and made sure they matched :), didn't know about chains being directional so will confirm that.
  18. jrs77
    jrs77 Modder
    17 Feb 2006
  19. Weekly_Estimate
    1 Feb 2010
    Nevermind :)
  20. legoman
    28 Feb 2010
    You could get a 7 speed cassette with a single ring up front, keeps the wheel options more open that way as its a normal cassette not a freehub. Or, to keep the ten speed idea just go wit ha 1X10 can be on a road cassette with 11-28T or go insane with a sunrace cassette an get a 11-42T with a something between 32T and 36T up front
    Frame wise what type of wheels you looking at? an any preference on material? Framesets are easy enough to get hold of itll be more colours and geometry
    Brake wise id err toward hydro if you can, more power, reliable an need little work once setup
