Education We Like to Ride Bicycles
Discussion in 'General' started by RTT, 8 May 2008.
  1. Vault-Tec
    30 Aug 2015
    Pink Cheesecake !
  2. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    When you say flex, are you meaning as you land and progress through the travel the fork flexes forwards from the base of steerer?
  3. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    Nope, the 36 has twisting flex. Backward and forward flex is fine and is associated with headset quality and fit etc. So regarding twisting flex, its not much but when you come off a jump and straight in to some tram lines the 36 has made me feel uneasy. I gave a go on a Zeb with 170 travel on a mates bike, sent that (much to his dismay) and it felt loads stiffer.
    So the way forward is 38 stanchions as I weigh as much as an average rider with an e-bike so over all weight is there. My theory is, if I run more Sag on the 190 travel it wont change up the geo. it also means I wont have quite as a hard and unforgiving feedback from the fork as I can run it softer unlike the fox 36 that needs some extra PSI in it to counter the side of pork.
  4. Cookie Monster
    27 Aug 2003
    I'm afraid that's beyond me. I've never really understood suspension beyond the basics.
    I've always been amazed how Greg Minnar could come down a hill and notice the difference between 6 and 7 clicks on compression.
  5. andrew8200m
    4 May 2009
    Well if I run more sag I have a softer front end and it stays within the same geo boundaries so I am hoping it wont feel too different in that respect but offer more in the way of smash smash when I need it.
    I can tell the difference between 0 clicks and 4 and then again when I get to 8.. I thought that was rather average but now I feel mediocre at best :D
  6. Cookie Monster
    27 Aug 2003
    But then will it also not extend more when your rebound kicks in and upset your geometry as it extends?
  7. andrew8200m
    4 May 2009
    Only if I set the rebound to fast, which I really dislike. So if I slow the rebound down to which I would prefer but can’t on the fox as it runs out of available travel too quick, I’ll be sat in the mid to mid top of the travel on a decent anyway given my rolling sag will be around 30-35%. Worst case, if I don’t get on with it, when I get the new 3.1 damper for it to make the latest 2025 model fork, I’ll also drop to 180mm.
    Due to the build of the zeb, the base of the stem to the centre of the axle is 21mm longer on the 190mm travel fork than a fox 36 160mm apparently . So with this in mind a happy middle ground might be to change out to 180 over the winter when I work on the bike and tuck it away until spring.
    This is why the enduro bikes rocking a fox 36 160mm sit slightly higher than a lyrik with the same travel length and about the same as a lyrik with 170mm of travel apparently. Learn something new every very day!
  8. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Jesus. I just hope and wonder if I've put the right size tyres on.
  9. Vault-Tec
    30 Aug 2015
    I masked up the seat clamp face and after sanding off some terrible touch up repainted it black. It needs clear next.
    Polished the bolt out too. The decals are on the way.
    andrew8200m likes this.
  10. andrew8200m
    4 May 2009
  11. Vault-Tec
    30 Aug 2015
  12. andrew8200m
    4 May 2009
    This colour way especially with that brake on that green is absolute fire! I love these “going out raving with my ankle warmers and cycling shorts” colours.
    Memories… :grin:
    Vault-Tec likes this.
  13. Vault-Tec
    30 Aug 2015
    If I didn't explain it properly before... It is supposed to be a water melon. If you look at the pink parts of the stickers you can see the pips.
    And yeah, we need to see more of it. Sunday bikes are all flat colours now or black. The stem I got for free arrived too. I was expecting this one (later)
    But what he sent was much harder to find. An original old logo one.
    I will work on that when I return in a couple of weeks, and then paint it pink also.
  14. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
  15. andrew8200m
    4 May 2009
    Nice! I've not been to the South Wales coast in 15+ years. 15 miles on a Cruiser BMX though, thats dedication!
  16. Cookie Monster
    27 Aug 2003
    Or stupidity???
  17. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Masochism?
  18. SuperHans123
    27 Dec 2013
    Cheers
    It's not quite a cruiser BMX, it's a Cannondale Treadwell (9 speed) with an extended stem.
    It bombs along beautifully on the coast path.
    Off work this week so a trip to Penclawdd is planned for Thursday. (25 mile trip)
  19. andrew8200m
    4 May 2009
    So, I’ve been looking in to new wheels for my bike too, 1 so that I can keep the set I have as a spare and 2 so that I have something a bit more robust.
    Anyway, I narrowed it down to DT Swiss H1900 and the Specialized Roval Traverse 350.
    The engagement angle is 15 vs 10 degrees in favour of the Roval. The spokes are the same. The hubs are DT Swiss 370 and 350 respectively with negligible difference and then there are the rims. Both the same width, similar depth but 2.2mm wall thickness on the Roval be 2mm on the H1900 leading to a near 10% stronger wheel set. Pricing wise, the DT Swiss can be picked up as a set for circa £400, the Rovals are £760 but half price at the moment coming in at £380. Needless to say, they aren’t Hunt wheels which I’ve been reliably informed a good at folding and I’m happy with the purchase price at sub £400.
    Time to get the muc off valves in, the tyres on and the second cassette fitted. I might buy some second discs too but that will have to wait as I’m not made of money..
    edit.
    Well I’ve got it all fitted and installed now. It’s looking clean, the new tyres feel very draggy but the over all weight even with slightly heavier tyres is actually ever so slightly less. Go figure!
    Unfussy, none shouty wheels with one very stealth branding which I love just like the frame with its lack of “Specialized” stamped down it.
    Running tubeless again with mucoff valves and Juicy Nipples caps.
    The bikes finished now, no need to change anything else, it feels just right for me.
  20. ModSquid
    16 Apr 2011
    What earth did you just say there? I need to learn more. I don't have long left.
