Education We Like to Ride Bicycles
Discussion in 'General' started by RTT, 8 May 2008.
  1. Guest-23315
    Guest-23315 Guest
    OH. MAH. GAWD.
    I hate bike shops, and I hate waiting... My saga continues... Having been told that my bike had been dispatched and would be 'here' on monday or tuesday, I go down to day to collect it, only to find.....
    IT DOESN'T EXIST! OOH MMMMAAA GAWD!
    No Trek 1.2 D's with a 60cm frame have been in the UK for 2 weeks... And now, I've gotta wait until AT LEAST the 11th of May... that an entire month after it was ordered... having said that, if its not here by the 15th I get 10% off the bike, and then 10% of the original price to spend in the store. :( pff
  2. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Where you getting it from?
    The site i linked earlier with the Scott i fancy isn't doing delivery on there treks, i wonder if there is a supply problem.
  3. Guest-23315
    Guest-23315 Guest
    Yar, its from SBR in Windsor... apparantly there is a Europe wide shortage of Trek road bikes..
  4. steveo_mcg
    26 May 2005
    Ah, i think that settles it i'll get the scott.
  5. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
    So I've had the Furious about a month now and it's bloody brilliant! :D
    Been down to Rogate for some FR and a couple trips to FoD for a bit of light DH and it just eats it up. Still taking it a bit easy as I'm only five months on from a broken knee but I'm certainly getting there again.
    The bike:
    And a vid of it being ridden on a wee trail I built, filmed by me, of me riding (yeah, it took ages):
    Clay Pigeons on PinkBike.
    Had paperwork through in the post today for my 2.5 months in Whistler starting June 13. Flight booked, deposit paid, ROLL ON JUNE WOOOHOO!
  6. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    updated my bike sins the last post, so here it is...
    also i fitted some nuke proof - war head bars, E.13 supercharge bash ring, and crank ring which isnt in this photo..
  7. RTT
    RTT #parp
    12 Mar 2001
    noice :D
  8. yodasarmpit
    yodasarmpit No longer the other Brett.
    27 May 2002
    Nice vid Dom. :thumb:
  9. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    nice vid!
    right - wondering if you guys could assist - in building my bike (or rather, collecting parts for it) i've realised i need a few specialist tool. I've come up with a way to mount the headset stuff... so far i know i need a device to help me screw in the bottom bracket - before i hunt tools out and order them - are there any other specialist item's i may need aside from spanners, screwdrivers, hammers, hacksaws and pliers? Also any recomended lubricants (as i don't even posses oil atm!) and places to lubricate other than "anywhere that moves".
    taa!
    RwD
  10. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    looking through my toolbox, i've got a crank puller, a cassette tool, a chain whip and cone wrenches. the only one of those you'll need for assembly is the cassette tool, but the others are good to have and not too expensive.
    i use locally made lube, the guys at the bike shop here have formulated some stuff that works really well for the trails here, and i use phil's waterproof grease which i think is also a local specialty. check at your shop to see what they recommend. the lube you use should be dependent on how dusty/wet your trails are. lube only goes on your chain and your pulleys. other joints should get grease.
  11. Malvolio
    Malvolio .
    14 Dec 2003
    Basic guideline as far as lubrication is to lube anything that moves, or anything that fits into something else (bolts, seatpost, ect). I personally never lube my seatpost, or pedal threads, and I've never had a problem with anything seizing, but it is one of those standard industry practices.
    For tools, just make sure you have a damn good set of allan keys, rubber mallet, cone wrenches (very thin open-box wrenches), good ratchet set, large crescent wrench (with a mouth that can open about 2-3"), a good, large pipe-wrench (you wouldn't believe how much that has saved my ass), good phillips #1 and #2, good small and medium flat-head screwdriver, good quality chain-break (I would never use anything without Park on the handle), and whatever installation tools are needed by your bottom bracket (external BB's need different tools than internal BB's).
    Optional tools would be a Y-tool (two varients, one with three allan keys in a Y formation, or three sockets in a Y formation), pedal wrench, reaming tools, frame squares, crank puller, spoke wrenches (it's something you've got to learn some day), taps, heili-coils (along with their respective install kit), good cordless drill, torque wrench, chain whip, freewheel/cassette tools, ect.
    For lubricants, I go with Finish Line oil and grease. Never had any issues with that brand, and I've been using them for years both at shops and at home.
    RinSewand likes this.
  12. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    As far as lubing goes I say go for the cheapest. I use chain saw chain oil myself - the bike specific stuff is a massive rip-off.
  13. Guest-23315
    Guest-23315 Guest
    WD40/Silicon Lubricant?
  14. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    No idea about silicon based lubes - provided they don't break down easily and and the required thickness/thinness I can't see why not.
    WD40 is not advisable - it's mostly solvent so it'll strip out anything in your chain first - doesn't carry a lot of lube as that is not what it's designed for plus it'll break down fast and leave your chain dry (and dirty as hell).
  15. DougEdey
    5 Jul 2005
    I got a load of GT85 when it was cheap at halfords (lying gits that they are) paid £3 for a can, bargain since it's £5 everywhere else :)
  16. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    I use GT85, TF2 or TF4.
    Don't use WD40, I can't remember exactly something to do with it having no teflon in I think. I'll find out and get back to you.
  17. DougEdey
    5 Jul 2005
    Mines GT85 as well...
    WD40 has acidic components as Ramble said, it strips off all the inbuild weather proofing on the gears and chain
  18. Malvolio
    Malvolio .
    14 Dec 2003
    WD-40 is about the worst thing you could ever do to your bike. It eats rubber seals, strips away any form of lubrication thats ever touched whatever it's being sprayed on, and needs to be cleaned off before you can lube the object again.
    I've seen far too many chains, headsets, bottom brackets, fork seals, bushings, ect absolutely destroyed by some idiot with a can of WD-40 than I ever want to remember.
    It's a mineral-based degreaser. Thats all. Use it on locks, or to clean random, non-mission critical parts, but never let it get within fifteen meters of your bike. Ever.
    Every time somebody uses WD-40 on their bike, god kills a handicapped kitten. Then drinks it's blood. And eats it's cheeks with a tall glass of chardonnay on the side.
  19. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Use a Teflon based lube, normal oil just attracts and holds dirt, and don't use WD-40 due to the above reasons.
  20. Unicorn
    25 Jul 2006
    +1, ruined only one cheapo bike before I learned my lesson about WD40. Would never let it anywhere near my current ones.
