Education We Like to Ride Bicycles
Discussion in 'General' started by RTT, 8 May 2008.
  1. Mathmarauder
    Mathmarauder What's a Dremel?
    14 Jan 2007
    I have a seal kit coming my way soon. I think it must be the issue because I seem to get the sag set perfectly at 25% and then after my ride it is sitting at 40% sag. Will running a slightly higher initial pressure reduce the bottoming effect? I realize with my leverage ratio it is only 4 inches of travel but a simple root or curb drop shouldn't bottom it with a clank, especially when the fork still has 4-5 inches of travel left.
  2. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    If the shock is new, send it back for replacement, losing air that fast is not normal.
    If it's used, send it off for a service, perhaps TFTuned or do it yourself.
  3. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    As far as I am aware, what TF tuned do in a standard service is an air sleeve maintenance. And if they find a real problem they charge big bucks.
    Not really worth it imho.
  4. weasal
    weasal What's a Dremel?
    22 Jul 2007
    Whats the best way to remove the cotter pins? Nothing to grip onto the end of the pin and hitting it hasn't worked at all....
    Chris
  5. Cptn-Inafinus
    3 Mar 2007
  6. Sirwashbrook
    Sirwashbrook Bacon is good for me!
    11 Mar 2008
    New Continental Tyres , Very Chunky I enjoy very much
  7. Mik3yB @ CCL
    Mik3yB @ CCL Everything is not going to be OK
    11 May 2010
    What model Conti's are they?
    I just got a Schwalbe Little Albert for the front, it's pretty grippy and solid (pumped up to 65psi and the nobbles feel almost like plastic to the touch rather than squishy rubber) so they might actually last for a good few months. Will be getting one for the rear too to replace my Michellin if it turns out any good.
  8. Sirwashbrook
    11 Mar 2008
    They are Verticals , and treds also feel very solid , had a blast up hill this morning on a dirt track and they dig in well so all is good
    :D
  9. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    That's pretty shocking for £85. I gather they replace the o-rings (which probably cost circa £50p) but it's probably 10 minutes of labour if that's all they do...
  10. Jamie
    12 Mar 2001
    I serviced my Fox RP23 in about 30-45 minutes. It's fairly easy to do.
  11. matt...
    matt... Slacker
    18 Nov 2009
    I use 'zocchi's and have never had to service them :)
  12. Jipa
    5 Feb 2004
    I have Marzocchi Dirt Jumper and it feels like it's in need of looking after. Then again, I just couldn't be bothered with changing the oil and checking the seals as it also makes a very, very ominous noise that I'm sure can't be fixed by any means of servicing...
    EDIT: tried to go for a spin last night. Yet another flat. FFS I think that's fourth for this summer.
  13. WarningFromSpace
    WarningFromSpace What's a Dremel?
    1 Apr 2006
    I did a ride with some folks who had a few, slow as balls going uphil
  14. Mathmarauder
    14 Jan 2007
    I replaced the seals and one looked just a bit off, almost like it wasn't a consistent diameter all the way around. After I finished I set the sag a bit stiffer than normal and went for a really long ride. It appears to be holding air a lot better and I can't bottom it anymore even when I try.
  15. Cptn-Inafinus
    3 Mar 2007
    Does anyone have any experience with servicing Fox Talas forks? The video walkthrough makes it look fairly simple, but sourcing parts is proving alot more difficult.
  16. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    Never serviced one, have you tried Mojo for parts?
  17. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Just been down to Glentress for the first time in nearly a decade, good fun! :D
  18. Golden-1
    Golden-1 Minimodder
    23 Aug 2003
    Went for a 25 mile trip today. Cant say that it was particularly slow going up hill on the way out.
    On the way back, however, it was a little slow.
    As a side note. : MY THIGHS! ouch.
  19. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I can almost guarantee your thighs don't hurt as much as my back/neck/thighs. :p
  20. Cptn-Inafinus
    3 Mar 2007
    I can almost guarantee your thighs/back/neck don't hurt nearly as much as my ass did after my 50 mile epic off road adventure of last week.
    On another note, worn cassette :( Yet more monies to spend.
