Education We Like to Ride Bicycles
Discussion in 'General' started by RTT, 8 May 2008.
  1. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    that is lovely
    if i had a shitload of cash just lying around i'd love to build up something similar (titanium frame+hub gears+~100mm fork) for dicking around in town and stuff like that
    titanium is so sexy, shame its so expensive too ¬_¬
  2. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    Hamish - If you check bike forums and Ebay often you can pick up some pretty good deals on secound hand Ti frames, you do have to be willing to look often and wait though. Something relatively modern from a reputable brand will start at around £500+ (used), but you can pick up older frames a lot cheaper, £200-£300 on a 90's frame with older fittings like V-brake or canti mounts etc. I really like how it rides, stiff and responsive but at the same time has a springy feel over rough surfaces\heavier hits, it takes the edge off of bumps without removing the feel for the suface your on.
    Format - I've hung them like in the picture, but I've alternated each bike so the first is hung by the front wheel second by back wheel and so on. That way you can get the bikes close together but still get them out, I spaced the hooks out half of a handle bar width plus a bit extra to clear the saddles (30cm - 40cm per hook).
  3. GeorgeStorm
    16 Dec 2008
    Any of you guys gone on bike tours/long weekend/week long trips with nothing but you, the bike and a tent kinda thing?
  4. format
    format What's a Dremel?
    30 Jun 2008
    Thanks dude. Ideally I'm looking for something that sits the bike more flush to the wall. If I had higher ceilings I'd get a pulley but that's a bit pointless in the current place.
  5. Hamish
    25 Nov 2002
    yeah probably even harder for me as im 6'4" and need a larger frame and most people seem to ride medium/16" size stuff
    on-one 456 ti is relatively cheap at 'only' £800 new tho
    its a future project really, i already have a hardtail, money would be better spent on a full sus trail bike i think :p
  6. GeorgeStorm
    16 Dec 2008
    And what are people's opinions on 2nd hand bikes?
    pinkbike.com has reopened up the possibility of getting a half decent bike, regardless of whether I choose road or mountain.
  7. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    nothing wrong with second hand, with the price of stuff nowadays, I think that's what I'd be doing.
    Just make sure to ask the right questions, and if its not right when you see it, walk away.
    My mate just got a bike off pinbike, swapped his 125cc dirt bike for a Specialised SX Trail. As soon as he got it back, I had a look. It didn't have the cranks that were advertised, the front wheel bearings were worn and the axle is worn. The tyres were all cracked and should have been replaced, the rear deraileur was bent causing dodgy gear shifting, and the inner crank ring bolts were all bashed up meaning a second ring can't be fitted to make uphills easier.
    He's had it about a month and is now wanting to sell it as its not really what he needed.
    He was impatient though, and just wanted the first thing he saw.
  8. GeorgeStorm
    16 Dec 2008
    Oh yeah, if I were to buy, I would make sure I knew exactly what I was getting.
  9. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I've been running tubeless on my Remedy since getting it in December. I've not had any punctures or issues with it. You do have to watch the tyre pressure pre ride though as it can leak over time. It's also possible to burb air when pulling cutties or cornering hard with low pressures so you've just got remember to keep an eye on them.
    The only problem with it is fitting tyres, it can be a bugger to get them to inflate which is why a lot of people use CO2 to inflate them when fitting the tyre. Once the tyre is in the bead they are fine.
  10. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    been rocking tubless for the past year, loving it, never get any punnys, remember to use slime!
  11. Jipa
    5 Feb 2004
    2 hour trip: 0,5 hours of riding, 1,5 hours of cutting wood. Next step will be 0,5 hours of riding and 3 hours of digging :D
    What a hobby.
  12. GeorgeStorm
    16 Dec 2008
    20mile ride earlier
    Went with a friend who has a cube aim, and he had a quick go on mine, and he started to understand why I was so much slower than him, said the frame was too small for me, and just generally the bike was a bit rubbish :p
    Really enjoyed the off road bits, and so am considering getting a new mountain bike and maybe putting road tyres on it for commuting over the summer.
    All you offroady type guys, any recommendations? Looked at the specialized rockhopper/hardrock, anyone had any experience? Am looking at the 2nd hand market, since I actually buy everything 2nd hand nowadays, would be looking for 500 max, ideally <400.
  13. Hamish
    25 Nov 2002
    On a similar note, I'm looking at second hand fox forks for <£300
    Preferably coil and 15QR but 20mm is fine too, rather stay away from 9mm dropout
    on ebay/pinkbike I'm looking at a couple of Fox 32 140mm Vanilla R 15QR, a couple of 07 Talas 36's
    Also a 36 Vanilla R ( this one doesn't list the travel but is probably 160(?) which is a bit long, 140 is as high as I want to go i think, its also more than £300 :p)
    Are there any issues I should be aware of with these forks, anything I should be asking about specifically etc?
    Thanks :D
  14. Jipa
    5 Feb 2004
    Woop de doop, finally got the shovel and a couple of friends and it's time to start renovating a dirt that has stood abandoned for a good couple of years.
    Haven't been jumping for a couple of years and the friends are really just getting into this stuff, so it's definitely time to start small (and to get a helmet... maybe.. some day)
  15. Otis1337
    28 Nov 2007
    had a wikid day at channock chase today, highly recommend it
  16. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Looking to buy something like this but don't want to spend hundreds of pounds want to use to cycle to work can you guys point me in the right direction. Ask my son and immediately he wanted to sell me one of his fixed cycle's.
  17. GeorgeStorm
    16 Dec 2008
    @ Otis1337
    Once I get a new bike, me and a friend or two are thinking of making a visit :D
    Am looking at a couple of Specialized Hardrocks, or a Giant XTC, any recommendations?
  18. Cerberus90
    23 Apr 2009
    I knackered my back up when we went last weekend, aching whenever I bend it. Was fine untill we did the rollers bit a second time, and something went.
    My mate has told me that someone is organising a Riders Guild event for next month on the DH tracks. If my back is better, I'll probably be heading over for a bit of fun.
  19. willowthewhite
    willowthewhite Minimodder
    7 Nov 2006
  20. frizzeh
    frizzeh What's a Dremel?
    5 Jul 2008
    I started to cycle commute to work on a Ridgeback momentum hybrid in february after using an old bike for 6 months. For the 3 weeks I used it I really enjoyed it until the handlebar stem suddenly jerked loose coming down a small hill out of work causing me to lose all control of the front wheel making it turn sideways and flip me over the handlebars D:
    Been off work and off bike since with a knee injury which is slowly getting better, aside from a few scratches and wrecked bar ends the bike was relatively unharmed fortunately! It's strange but through this whole recovery period the thing I have missed most is riding my bike, especially with all the beautiful weather we have been having :p
