Modding web cam modding (IR)
Discussion in 'Modding' started by eaterofpies, 18 Feb 2003.
  1. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    well i got really bored tonight and modded my webcam just a simply got a bit of an infra red filter from an old remote and taped it on the fromt of my webcam i wouldnt have bothered posting but i thought the pics were interesting
    the 2 lights are about the same brightness in the visible band but in infra red . . . well heres the pics
    firstly a flourescent lamp (the ones that take less power
    and now a bog standard fillament lamp
    if anyone else tries this post some pics
    oh and i tried it outside earlier its well wierd :)
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    B/W spy cameras also create some awsome effects with a IR filter.
    I have a piece of crap $19 webcam that I haven't used in years mabye I should try and hack it.
  3. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    correct me if im wrong, but "IR modding a webcam" means to crack it open and remove the IR filter...putting another filter shouldnt allow it to see IR(unless 2 filters cancel each others effects out).
  4. ZapWizard
    19 Sep 2002
    Umm webcams dont have IR filters to remove, he simply added a IR filter to a normal webcam. Most camera's can see IR on some level, it just depends on the camera.
  5. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    here's the recipie for extreeme fun....
    1x Vid Camcorder w/Night visiony thing
    1x Roll of coloured tape.... eg duct tape...
    2+x Remote controls
    Infinitum x sillyness
    simmer for 20 mins add duct tape to front where the IR is on the vid cam switch to night vision mode... go in front in the dark...
    the force is now with you.... battle with people using the wonderous volume buttons(or whatever)
