Windows Web interface for file system windows server
Discussion in 'Software' started by lysaer, 15 Sep 2014.
  1. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    Does anyone know a piece of software for Windows server 2011 which can run as a webserver and allow external access to specific folders.
    The idea is to have a bunch of folders i want to make available on the Internet for people to access with a simple login interface, so different users would have access to different folders.
    Thanks in advance all
    Sent from my SM-G900F using Tapatalk
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    FTP ?
  3. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    If it's SBS 2011 then the feature is already there with OWA. Or you could use VPN connection straight to the server.
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Maybe webdav? Then you can let them access the data like a network share as it can be mapped to appear as such. It works well enough and should be pretty straight forward for most users.
  5. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    Options are:
    Remote web workplace on SBS should give you folder access,
    Look into OwnCloud
    FTP maybe
    build something of your own?
  6. phuzz
    phuzz This is a title
    28 May 2004
    One thing to remember about FTP is that your login details are sent in the clear, so it's quite easy for someone to capture your credentials.
  7. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    If it's 2012 and you mistyped you can simple install the Remote Access role and it will install a site with login for you.
    2011/2008/2003 SBS was Remote Web Workspace
  8. lysaer
    15 May 2010
    It's for some clients and really needs to be browser based for ease of use.
    I will check out OWA does it offer an html interface I could customise
    I will have a look into webdav now
    I will check those all out now
    Yeah it's 2011 SBS, but it's not remote access I want
    Basically I'd like to share certain files with clients and give them a browser login with access
    Thanks for all the input guys I will check out some of the suggestions
  9. saspro
    saspro IT monkey
    23 Apr 2009
    Sharepoint would do it as well
  10. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    you bad man, are you trying to give him a headache, you know it can be a pain when it all goes wrong
  11. saspro
    saspro IT monkey
    23 Apr 2009
    Like a system I've ever installed has gone wrong :rolleyes:
  12. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Hahaha, You're both right. Sharepoint is a pain even when everything goes right.
    Back on Topic, I second OwnCloud.
