Development Web page help
Discussion in 'Software' started by smc8788, 6 May 2009.
  1. smc8788
    smc8788 ...at least I have chicken
    23 Apr 2009
    OK, so I'm quite new to HTML/CSS coding, so please bear with me. I'm in the process of building a basic site, but need your help with something.
    What I want to do is have a page where a random image is chosen and displayed from a predefined set (of around 50 or so) when the page is loaded, and a new random image is displayed each time the page is refreshed. Most of the images are the same size, but some are in a different orientation/resolution.
    What would be the quickest and easiest way to implement this? Would I need to utilise Javascript to achieve this (which would only confuse me more)?
    TIA for any help :thumb:
  2. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    This will very likely do the job for you. If it doesn't just google "javascript random image" :)
    http://www.javascriptkit.com/script/cut118.shtml
    There are so many code repositories out there for bits like this that you don't have to worry too much about learning the programming languages to do it yourself :)
  3. smc8788
    23 Apr 2009
    Cool, I'll take a look at that and see how well it turns out.
    Thanks :thumb:
  4. Firehed
    15 Feb 2004
    You'll either need to use javascript or a server-side scripting language (PHP, ASP, etc); each have somewhat of a learning curve and tons of examples.
  5. rolly74
    rolly74 Digital Marionette
    21 Apr 2009
    You can also use flash scripts that do that and come with some nice visual effect on top
  6. Atomic
    Atomic Gerwaff
    6 May 2002
  7. barack
    barack New Member
    11 May 2009
    it requires some sort of javascript and php to implement it perfectally.
