A/V Webcam Help
Discussion in 'Tech Support' started by sparkyboy22, 19 Jun 2010.
  1. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    Got a laptop running Win 7 x86.
    Device Manager has a USB 2.0 PC Camera showing under other devices without drivers installed.
    Prior to Win 7 install Webcam was showing as GenesysLogic usb 2.0 camera
    I cant find any windows 7 drivers for this, anybody got any ideas of driver alternatives that might work with this?
  2. seanbean
    seanbean Certa Cito
    21 Apr 2010
    Post deleted (dodgy link)
  3. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Don't you think it would be wise to remove the link then.
  4. Zerolimitz
    Zerolimitz What's a Dremel?
    26 Jan 2010
    1st thing that comes to mind is running compatibility mode and running it as administrator / win xp etc and see the out come.
  5. sparkyboy22
    3 May 2010
    I tried installing in compatability mode logged in as local admin and run as administrator just to be on the safe side and seems to go through the install process fine.
    When attempting to use though only shows an empty black box where the image should be.
