Development Website Design 'ToolKit'?
Discussion in 'Software' started by G-gnome, 5 Nov 2003.
  1. webchimp
    webchimp What's a Dremel?
    9 Oct 2002
    Notepad, Pah! I code directly in binary:
  2. death_star
    death_star What's a Dremel?
    14 Jul 2003
    ROFL!!!!! Thanks for making my day!
  3. batsman
    batsman the quiet one
    14 Nov 2001
    if your lazy (like me sometimes) adobe photoshop album will produce image gallery's in seconds that can be then uploaded to webspace. is useful for large number of images
  4. michaeln3
    michaeln3 What's a Dremel?
    20 May 2003
    I use a Macromedia Fireworks/vi combination when working on websites. I like the Dreamweaver coding part of the application, but the WYSIWYG is a pain. It only does what you tell it to, and all of those attributes turn into a mess. It's best used as a supplement, if at all.
  5. [S]lammer
    [S]lammer Can't touch this!
    30 Sep 2002
    lol, you said it dad...
    Anybody ever try maintaining over 50 sites using textpad/notepad?? :eyebrow:
    no self-respecting web designer uses only text based editors... it just takes too long... ;)
  6. michaeln3
    20 May 2003
    That's what scripting languages are for. :)
    I take back the part about DW's WYSIWYG being bad though...if you have huge tables of data, it's the only good way to put it in. (assuming you can't dynamically generate it)
  7. r-gator
    r-gator What's a Dremel?
    29 Jan 2002
    I've got Studio MX and the only piece I use from it on a regular basis is Flash MX. I've used Dreamweaver in the past and find that while it is good in some respects, I don't typically prefer the way it codes the page.
    It basically comes down to personal preference as was mentioned before.
    If you can get your hands on a copy of Microsoft InterDev .NET, it's my personal favorite. It's got functionality for all web programming languages (except for java, damn microsoft), the colored syntax is completely customizeable, you can have it autoformat all of your tags on the fly, and it also includes a built in page viewer (based off of IE) that allows you to see how your page looks in progress (image tags don't preview well with relative addresses though).
    HTML isn't hard to learn or use, but it's also limited in what it can do. In come the scripting languages, VBScript, Javascript, DHTML, and XML/XSL. These allow you to do just about whatever you could dream up.
    If you are interested in learning flash and have questions, I'd be more than happy to help you out. I have designed flash interfaces for several companies. It's also easy to learn but hard to master, as it is very versatile.
    I'd also reccomend reading up on site usability. Two great books are web pages that suck, and more web pages that suck. These will show you what not to do. If every one would only read these books we'd have a lot less crappy web pages out there.
    Hope that helps.
  8. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Amen :thumb:
  9. michaeln3
    20 May 2003
  10. r-gator
    29 Jan 2002
    why does the logo for alistapart.com look like it's flipping me off?
  11. RR5
    RR5 What's a Dremel?
    7 Dec 2003
    I'll vouch for Photoshop for image editing/creation and Imageready for web based graphics. I think they are at version 8, but starting at version 6.0 Imageready 3.0 was included.
    If you want simple html editing, FrontPage express does come with windows and it should serve as a starting point. After you master using it, Dreamweaver should be your next stop.
    Macromedia MX or whatever programs make those SWF Files, or vector based web animations everyone loves.
    There is a free open source html/code editor called Gvim, based on VIM for linux. It uses color coded highlighting. Go here http://www.vim.org/download.php
    In the end, its all arranged like this: Use Adobe to make images for your site, either notepad/gvim/outlook express or dreamweaver to construct the HTML code for your site. If you want pretty inbrowser movies, learn Flash MX.
  12. michaeln3
    20 May 2003
    Wow, Frontpage and vi in the same recommendation. :D Vim has a steep learning curve, but once you figure it out it's incredibly easy to get things done. Assuming you're a keyboard-shortcuts type of person.
  13. phenomx3
    phenomx3 What's a Dremel?
    4 Oct 2003
    Dreamweaver is mans best friend. It tears notepad apart with its validation. It just laughs at frontpage with the rest of us :D
    I have:
    Dreamweaver MX 2004
    Fireworks MX 2004
    Flash MX 2004
    Photoshop 7
    Photoshop Elements 2
    Zend PHP Studio
    I first started with dreamweaver 4 years ago. It has carried my back for so long now. You cant help but start to understand HTML with it because it seems it is in its nature to make you learn it. The extensions you can download for it are just fantastic.
    Fireworks is a nifty piece of kit which is squarely aimed at web designers. If you just plan to do web design then give this the nod over photoshop. If you feel that you make like to incorporate really top notch artistic style graphics into your website then go with photoshop.
    Flash is cool...only get to learn it when you have mastered web design for a couple of years
