Education Website designs
Discussion in 'General' started by icutebluezone, 6 Jun 2008.
  1. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
    Hi all Bit-tech needs. lol
    I have just been looking round at website design sites and have fround alot of them have the same template designs for sale and one place that you can buy the site and its removed and never for sale again how can the sites be all selling the same template designs? Do the companys buy a Software package with all the templates in it on cd's or dvds?
    This is the main site i love and that you can buy them and thay will remove them but i have seen the same templates on other sites. Sum of the sites just about have all the same designs.
    http://templates.entheosweb.com/
    Couple sites that have same designs are:
    http://www.steves-templates.com/templates.html
    http://www.websitetemplates.com/
    http://www.top1000templates.com/computer-templates/
    http://www.5shadestemplates.com/
    Are the sites all linked to the one owner or what? :confused:
  2. imkeller
    imkeller What's a Dremel?
    8 Aug 2006
    Maybe people get re-sale rights when they buy them? Although this seems highly unlikely..
  3. icutebluezone
    6 Aug 2007
    Dont no aye Think the only way that thay could maybe do that is if thay buy the site and not just buy the template design but just about all the designs cost like $1500 + seen sum for $5600. But if thay did buy them it would cost $10000000000000's to get them all and the other site's still have them. Strange to me lol. Mite have to look into it more. :)
  4. icutebluezone
    6 Aug 2007
    Ok was chatting to one of the tech people from the website http://templates.entheosweb.com/ and thay are all owners of the sites that have the same template designs and if you buy the design off one site thay remove it off all the sites.
  5. dragon2309
    dragon2309 techie
    28 Jul 2006
    This makes sense, but you could just make you're own... What you'll find with these templates (or at least a lot of them) they will be poorly put together to look nice, behind all of the nice exterior will be a painful tables based layout.
  6. icutebluezone
    6 Aug 2007
    Yeh most ones i have ever downloaded have been ****. i have made sum and making one at moment.
  7. naokaji
    naokaji whatever
    8 Dec 2006
    many of them are created in a wysiwyg editor supercheap and then sold as "professional" stuff anyway.
  8. Glider
    Glider /dev/null
    2 Aug 2005
    Take a look at OSWD for some great free CSS templates.
  9. icutebluezone
    6 Aug 2007
    Hay thanks will have a looky.
  10. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    CSS + DIVs are win. Tables are fail. :)
  11. tominated
    tominated What's a Dremel?
    28 May 2008
    templates aren't very good for the $40+ you usually pay for them. I mean sure, i make templates, but they are for a specific mac program(rapidweaver), the are full xhtml & css and they are only $10. But i do find it strange that heaps of different sites claim ownership to web templates by other sites.
  12. icutebluezone
    6 Aug 2007
    Yeh i have made sum designs and own sites before. Plus tryed free templates never brought a template. I use Microsoft Expression Web Studio and have got Photoshop CS3 and a couple other little editors.
    Yeh very strange i think about the sites having the same designs on a lot of sites.
  13. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    Maybe they own so many copies of the same storefront to help dilute complaints against them.
  14. icutebluezone
    6 Aug 2007
    Just to let you all no. I brought a website design off http://templates.entheosweb.com/
    I had a spear $60 on a visa gift card that i needed to use and didnt have anything i realy want so I tested a website template site out to see how good thay are. got one of there low budget sites $30 US. But is still a nice design and has a flash banner at the top if you want to.
    Its so easy and fast and after you make your order and pay thay ring you to check everything and then email you right then. BLOODY FAST service.
    In the email you get a link to your Zipped website design and also a password to uncompress and unencrypt the zip file.
    The unzipped file has 4 folders 1html file and 1 readme. Website Sources: .SWF; .FLA; .PSD; .HTML. Has loads of files and fonts, clipart, logos, buttons and more.
    Looks like i have a new thing to play with lol. will edit it a lot and change colors.
    Screen shot of the website design.
  15. ComputerKing
    8 Sep 2006
    so now what u do ? edit or what?
    Because I'm looking to buy one too and edit it :)
  16. DarkLord7854
    22 Jun 2005
    Is it made in tables or divs?
  17. icutebluezone
    6 Aug 2007
    Yeh edit it and will most likely change the colours and most likely remove and add things to the design. Its got PSD files for everything. Also Flash files that you can edit.
  18. icutebluezone
    6 Aug 2007
    Tables. but can easyly be changed. There is psd files and all that.
    I will upload a page to my host and post a link to it on here for you to have a look at the code.
  19. icutebluezone
    6 Aug 2007
  20. DarkLord7854
    22 Jun 2005
    Don't think me an asshole, but that layout is made entirely of tables. Tables are horrid for styling and a pain with search engines generally. You should also center the layout, it's aligned to the left right now.
