Displays Weird display issue
Discussion in 'Hardware' started by N17 dizzi, 2 Mar 2017.
  1. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    I've got a Dell SE2717H that is occasionally going black for a second before coming back on, and it appears to coincide with the fridge compressor switching off (which it does with a popping noise).
    The fridge has done this since I moved in, and my last monitor didn't have the problem.
    Is it the fridge, the screen, neither or both?!
    Any help very appreciated!
  2. Vault-Tec
    30 Aug 2015
    Ground issue perhaps?
  3. N17 dizzi
    23 Mar 2011
    I've no idea. It's a head scratcher. Not sure if I should RMA the screen or ask my agent for a new fridge.
  4. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    How frequent is the issue? Could test by switching the fridge off for an hour or two.
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    I have this at work on one of my two screens. It'll randomly go black for a couple of seconds.
  6. Vault-Tec
    30 Aug 2015
    I would get a UPS tbh. It really doesn't sound good. Do you have your PC on the same supply?
    If it's a ground issue the monitor may think that the PC has been shut down, turning itself off.
  7. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    - Stick the fridge on a surge-protected strip
    - Wrap a the power cord for the fridge through a Ferrite Choke
    If that fails
    - Ferrite Choke for the screen too (power cable and video cable)
    - Surge protected strip for the screen too.
  8. N17 dizzi
    23 Mar 2011
    Thanks for the input. I was going to try a new HDMI cable for the screen. I'll definitely put the fridge on a surge protector and see. The monitor already has one.
    I don't have any Ferrite Chokes. Is this something one can just add to an existing power lead?
  9. N17 dizzi
    23 Mar 2011
    It is very infrequent. Coinciding with the fridge compressor which happens a few times a day. Not sure if I should still RMA the screen, as it may be very susceptible to electrical noise.
  10. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    I had this with my 4K display when I turned my A1 Amp on.
    After lots of fiddling and cables. I found the only fix was to use a thick insulated HDMI cable.
    2 other displays connected to the same PC gave no problems when using the same cables as I had issues with on the main display.
  11. N17 dizzi
    23 Mar 2011
    I have now put a surge protector on the fridge lead. I can try a ferrite choke and thicker HDMI if that doesn't work. So far it hasn't happened, the compressor is running on the fridge as I type this. So, we'll see.
    Thanks for the advice, all.
  12. N17 dizzi
    23 Mar 2011
    Having tried the above I can say that the monitor is faulty. It goes black in reaction to at least two devices in my home.
    Lamda-tek have asked me to return it at my own cost. I'm not sure about that, I've only had it a few days. Other retailers pay for return shipping on faulty new items.
