Displays Weird monitor issue
Discussion in 'Tech Support' started by Parge, 20 Feb 2016.
  1. Parge
    16 Jul 2010
    So, when I boot it from cold, after a random period of time (usually between 5-15 minutes) the screen loses signal and the computer requires a reboot. It then happens again, around the same length of time after that.
    Following that though, its absolutely fine, and I can play games etc for hours without any issues.
    Any ideas?
  2. Parge
    16 Jul 2010
    Actually, I think it might be GPU related, since I recorded myself playing twitch, and the whole stream stops.
  3. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Got a spare GPU to test? Got a 560ti here I can send down if you need a card to test bud.
  4. jinq-sea
    15 Oct 2012
    Be thankful it's an EVGA. I've also got a GPU kicking about you can test with too if you like - I can hand it over when we finally get that beer locked in!
  5. Parge
    16 Jul 2010
    It was my CPU overclock. Weird because it was 100% stable for 3 hours in AIDA64 but has this issue.
  6. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Had that before, passed every stress test ever and seemed 100% stable. 10 mins into a game and crash. I don't bother OC'ing anymore unless it's needed to squeeze a few frames out of a system.
  7. Parge
    16 Jul 2010
    OK, so I don't think this is actually my overclock, or my GPU, or my monitor.
    Basically the crash only happens when initially booting up the computer from cold. Once everything is warmed up (as in temps) its rock solid. I'm thinking PSU at the moment.
  8. Parge
    16 Jul 2010
    Replaced the PSU and noticed that the wires on the front audio jack and the 3rd fan header were totally squashed in (they are in line with the GPU. Hooked the fan up to the GRID+ and removed the audio and everything seems rock solid now. Trouble is, I don't know if the PSU or that was the cause!
