Windows Weird Screech Sound Periodically From Speakers?
Discussion in 'Tech Support' started by Tibby, 30 Jan 2012.
  1. Tibby
    Tibby Back Once Again
    9 Oct 2005
    Hey All,
    Built a new PC in Oct/Nov last year, and it's all hunky dory, but I get a weird screeching sound sometimes out the speakers, and it is mostly triggered by the end of a round of BF3, although sometimes it has gone into overdrive and just started doing it every 10 seconds.
    I am going to do the obvious and update drivers etc. But just wondered if any of you had a similar issue and know the answer?
    Cheers!
  2. moorsey
    moorsey What's a Dremel?
    10 Oct 2009
    is it deffo out of the speakers? Only I get some electrical whine from my GPU when playing games sometimes. My mobo did the same until I disabled some power stepping option also
  3. Kernel
    Kernel Likes cheese
    29 Sep 2003
    is the sound kinda like someone keying off on an old CB radio?
  4. Tibby
    9 Oct 2005
    Wouldn't know about the CB radio, and it's definitely out of the speakers as it increases in volume when the speakers are turned up.
    I'm guessing it is a driver issue or something, but figured best to throw it up here as Google doesn't do well with an ambiguous description of problem based on a 'Screech'. :lol:
    I'll post up here once I find a fix, in case anyone else gets the same issue.
  5. Kernel
    Kernel Likes cheese
    29 Sep 2003
    I think I do have the same problem, mine makes a CB Radio sound, coun't figure out what it was and just suffer it now, but it's fairly intermittent
  6. Jackg
    Jackg What's a Dremel?
    7 Jul 2011
    Does it ever happen outside of battlefield 3?
    Cause whenever battlelog finishes a battle report it seems to make that noise for me.
  7. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Could it have something to to with the VOIP on battlelog?
  8. Jackg
    7 Jul 2011
    Never used the VOIP on battlelog, but it still happens after almost every round.
  9. Kernel
    Kernel Likes cheese
    29 Sep 2003
    I have never used it either, just wondering if it has anything to do with it.
  10. GoodBytes
    20 Jan 2007
    Set Volume to 0, and mute Line-In, CD-In, Aux, Mic, and any other inputs. Recording and Playback.
    Also plug your speakers/headphones on the back of your computer, if they are not already.
    Does this help?
  11. Deders
    Deders Modder
    14 Nov 2010
    It's not feedback is it? are you using a microphone?
  12. Tibby
    9 Oct 2005
    Hey guys, went straight out last night and haven't touched my PC so haven't had a chance to look at this.
    It always happens in BF3, but then sometimes it will carry on outside of the game when I'm watching a video or something.
    I do sometimes find that the BF3.exe process doesn't exit properly and this could be a cause.
    I'll make sure all inputs are muted when I get a chance GoodBytes and see if that fixes it.
