Linux Weird sound problems in ubuntu 7.04
Discussion in 'Software' started by DougEdey, 29 May 2007.
  1. DougEdey
    5 Jul 2005
    I;m running a DFI Lanparty UT NF3-250GB board and using the onboard sound over Digital.
    It runs perfectly in windows, but in Ubuntu it doesn't consistently work.
    If I use Gaim, those sounds play fine, but youtube videos and other stuff doesn't!
    Any ideas?
  2. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Is it just youtube videos that don't work, or is it stuff like media players too?
    If it's just youtube, what browser are you using?
  3. DougEdey
    5 Jul 2005
    It was everything, but now it's just youtube/all flash. Using Firefox 2.0.0.3
  4. macdude425
    macdude425 What's a Dremel?
    13 Mar 2005
    Try to sudo alsaconf. You DO have the newest version of Flash, correct?
  5. DougEdey
    5 Jul 2005
    yerp, latest from the adobe website
    alsaconf not found.
  6. ozstrike
    19 Sep 2004
    I can't quite remember what I had to do, but it was something like
    "aoss opera"
    from a terminal, and it forced opera to open with alsa-oss.
    You could try "aoss firefox" (or whatever the command for firefox is)
  7. DougEdey
    5 Jul 2005
    I gave up with it, Linux support for devices has proven to have failed again where Windows succeeds.
  8. Glider
    Glider /dev/null
    2 Aug 2005
    Ubuntu has failes... In Gentoo I never had any problems with sound... USE flags Cheesecake!
  9. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    How about trying 'apt-get install alsaconf' and if that fails 'apt-cache search alsaconf' rather than giving up because you don't have the app preinstalled.
  10. DougEdey
    5 Jul 2005
    Tried both off those with Glider before hand. Sorry but untill Linux can give support as easily as Windows it won't gain ground.
  11. Fophillips
    9 Oct 2006
    It's not Linux that's not giving support, it's the hardware manufacturers not opening their drivers.
