Windows Weird stuff happening while creating a recovery drive.
Discussion in 'Software' started by Xir, 4 Feb 2015.
  1. Xir
    Xir Modder
    26 Apr 2006
    As a recovery drive lives in my tiny ssd (8.5GB of 32GB), I wanted to get rid of it.
    Windows 8.1 tells you to get a 8GB USB-Stick (or partition) so I did.
    My first mistake:
    A 8GB stick is too small, as it in fact has only 7.6GB or so and Win8.1 will not accept it. :duh:
    Arright, so a partition.
    I have a 500GB data drive in the system, that’s 470oomphGB in real life.
    I reduce it by 8.5GB to give me a 8.3GB formatted partition. (the original recovery partition is this size)
    I now have
    C: 32GB SSD (with an invisible 8.3GB recovery partition)
    E: 468GB HDD
    F: 8,3GB HDD
    so far, so good.
    I now select the „create a recovery drive“ option in Win8.1, it finds E: and F:.
    I choose F:
    It tells me “Warning, F: will be deleted” which is fine. I click OK and it starts to write the recovery drive.
    E: AND F: are formatted and repartitioned! :eeek:
    I now have a 32GB recovery drive E: and the rest of the 500gb drive as non partitioned.
    My data is gone of course. :grr:
    Bwech, did I click something wrong?
    I reset the internal harddrive to be one partition 470ooomphGB again, and repeat the process above:
    The same result.
    Can anyone explain this behavior? Where’d I go wrong?
    Best Regards,
    Xir
