Windows Weird Win2k problem, PLEASE help.
Discussion in 'Software' started by acrimonious, 12 Jul 2003.
  1. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    When i boot up windows tells me that the user profile could not be loaded and it is possibly corrupted.
    It was working fine the day before and i havent made any changes to my system at all since then, i can't understand it.
    It there anything i can do to solve this problem?
    Thanks in Advance,
  2. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Can you get into your admin account, copy the user info, delete the user, create a new user, and load the old info into the new user?
    It's probably become corrupt (go figure) :p That used to happen to me sometimes, was windows' way of saying "HEY STUPID! IT'S TIME FOR A FORMAT!" :(
  3. acrimonious
    8 Nov 2002
    Yeah the thing is i'm on a HDD thats only a few months old with a clean Win2k (well about 4weeks old) install on it.
    I'll try that though, cheers.
  4. SerpentBlade
    SerpentBlade What's a Dremel?
    10 Apr 2003
    have you installed the latest Service Packs (dumb question), but a lot of problems like that are caused by not having service packs... naturally I am probably wrong
  5. RTT
    RTT #parp
    12 Mar 2001
    My mate had the exact same problem. He created a new profile but the problem recurred, a format solved it.
  6. acrimonious
    8 Nov 2002
    Good point, i don't think i have on this install.
  7. acrimonious
    8 Nov 2002
    Okay copied the Documents And Setting folders after setting up a new accout, works okay its forgotten all my settigns but hey, but Outlook Express doesn't show me any of my stored e-mails, anything i can do about this?
  8. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    If you have already deleted your previously used profile then no, unless you have some good data recovery software.
    Otherwise you can find all your data in the following location :
    C:\Documents and Settings\your profile\Local Settings\Application Data\Identities\{89E085C0-84E0-4D4C-BCF8-64D4D4DD9C3C}\Microsoft\Outlook Express.
    Copy all the contents of that folder into your newly created profile and it should work (I think).
  9. acrimonious
    8 Nov 2002
    I copied the whole folder in documents and settings for my user name into the new user name.
