Electronics Weird Wires!!!
Discussion in 'Modding' started by felix the cat, 25 Jul 2002.
  1. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    didnt know whether this would be better in modding but here goes...
    im looking at extending my wires to my cc's so i was wondering whether i need to try and find some cynar/cinar wire (if thats how you spell it) or whether i could get away with using some normal wire...
    cheers for any thoughts...
  2. viridius
    viridius What's a Dremel?
    7 Apr 2002
    Just make sure the insulation can handle the voltage. 600 volts minimum.
  3. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    there was a massive discussion on this once before.. i managed to get away with standard 18ga hookup wire.. rated 600v from radiohack.. however i tested with a longer piece, and a rather long (more than a foot or so) and the brightness slowly dropped..
    if you perfer hi voltage wire, the wire from a old set of test leads should work.. :)
    -scoob8000
  4. felix the cat
    11 Jan 2002
    so as long as my wire and my heatshrink can take 600V it shuold be a problem??:idea:
  5. scoob8000
    17 Feb 2002
    thats the theory of it anyway.. :dude:
    just use quality wire and youll be fine..
    -scoob8000
  6. Annihilator2
    Annihilator2 What's a Dremel?
    27 Jul 2002
    if u really want to get the proper stuff then go to digikey.com and buy part number:
    W2722R-100-ND for red
    W2722B-100-ND for black
    W2722Y-100-ND for yellow
    W2722G-100-ND for green
    its rated 5,000volts and is more than adaquite
    its $12.95 for 100ft.
    oops you probably don't live in the U.S. but maybie this will help someone
