hi, I have windows XP Pro, is there any way of changing the welcome screen at the start of boot, or even getting rid of it?
Boot Screen Hi, I have managed to change the boot screen using "LogonUIBootRandomizer" Thing is this annoying screen comes up as it boots: The top choice is for my changed boot screen, and the next one down is the normal windows boot loading screen. I do not know how to get rid of this, some one told me it is to do with WindowsXP service Pack 1, and that it does not work by using any boot screen only compatible ones.
Try going to system properties >> advanced >> startup and recovery settings >> then edit the startup options so only the one you boot from is selected. Hope this helps!
