Modding Welder up for Grabs :)
Discussion in 'Modding' started by BobbyMParr, 5 Sep 2004.
  1. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    Hello all i am willing to make custom cases or whatever you need outta STEEL and steel only
    Deal is you send me a blueprint with exact sizes i check sizes check price of steel and type of steel you want then i get back to you with the price of the steel/and the price of labor total then if you agree i will need 50% of the full price to purchase the steel to start and then the other 50% when job is completed " BUYER PAYS ALL SHIPPING COSTS " plz contact me via bobbymparr@yahoo.com or aol aim BobbyMParr thanks :) :dremel:
  2. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    can we get some examples of cases you have already built? (if youve built some before)
  3. BobbyMParr
    18 Jun 2004
    i have never built a case before but i have built 2 barn,a go cart ,and various other projects
  4. dmcm01
    dmcm01 Banned
    15 Aug 2004
    i cant realy take you offer up (due to logistics) but this is what this site needs........great idea mate :dremel: :thumb:
  5. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    Thats a nice Idea. I dont think a lot of modders (hardly any) use welding because most of them don't have access to an any sort of welding machines. I'm currently studying to become a welder, and from time to time, I've used the machines on my case. The only problem I could see is most people don't know how to draft blue prints for welds
  6. toyomatt84
    toyomatt84 What's a Dremel?
    1 Jun 2004
    Dam, I just bought a case too. :(
    I would have taken the offer up, but after spending $160 on the new case I'm getting, I'm broke. Sorry, and best of luck.
  7. mobius9
    mobius9 Minimodder
    4 May 2004
    after the great success of the lan-li maby just make a rectangular box with the bays cut out.
  8. funkymunky
    funkymunky Guest
    shouldnt this be moved to the for sale forum, as its the selling of a service???
  9. BobbyMParr
    18 Jun 2004
    ya well as in blueprint i mean mainly just the size of depth,width,heighth and i would probably charge about $55 for a standard case "thats including the materials"
  10. BobbyMParr
    18 Jun 2004
    sorry for the double post here "i cannot make the side panels only the frame of the case sorry i forgot to say that earlier"
  11. BobbyMParr
    18 Jun 2004
    ok well been a little bit and no replys maybe most modders dont need anything welded hmm well who knows :sigh:
  12. mobius9
    mobius9 Minimodder
    4 May 2004
    why not the side panels? they don't have to include all that special jazzy crap. Internal hinges would do fine for me. I'm interested if you would be able to do something like that. Could you basically make a tower with none of the bays/holes cut out on it? The doors shouldn't be that hard to do.
  13. hilmana
    hilmana What's a Dremel?
    20 Aug 2004
    i really think its not worthid to do all that and probably steel is VERY expencive $$$$$$$$$$$$$$$$£££££££££££££££.
  14. ShagBeard
    ShagBeard What's a Dremel?
    8 Oct 2003
    you are talking TIG right?
  15. BobbyMParr
    18 Jun 2004
    Stick welded then grinded then stick welded once more then grinded to perfection .
    Ps I will look into adding a sheetmetal sidepanels " i will check price and cutting price" ok mobius9 ?
  16. BobbyMParr
    18 Jun 2004
    steel is very expensive , a little heavy, but look at all the modding possibilitys i mean if ya screw up its possible to fix it easier than the alum. cases
  17. ShagBeard
    8 Oct 2003
    stick? stick isnt purdy enough imo. need nice TIG welds.
  18. BobbyMParr
    18 Jun 2004
    hey i know stick looks a bit bad hince the welded, grinded, re welded and then re grinded by then you cant tell if it was welded with tig, mig , stick or heliarked
  19. tomd
    tomd What's a Dremel?
    2 Feb 2003
    errr TIG = Heliarc
  20. BobbyMParr
    18 Jun 2004
    ya well whatever
