Networks WEP is useless and now cracked in seconds
Discussion in 'Hardware' started by Guest-16, 8 Aug 2006.
  1. Guest-16
    Guest-16 Guest
  2. riggs
    riggs ^_^
    22 Jul 2002
    Hmm, well I'm glad I don't live in a city - I doubt anyone around here would actually bother trying to crack the WEP code and access my network (hell, there's a bloke over the road who doesn't even bother with WiFi security!)
    And I've never had any luck with WPA either; tried it once, couldn't get it to work, so switched to WEP.
    Plus, my DS doesn't support WPA anyway...
    I wonder what security they use on the WiFi enabled trains? I've got a 4 hour train journey on friday, and wouldn't mind doing a bit of free surfing on the way...wink wink
  3. tacticus
    tacticus What's a Dremel?
    14 Jan 2006
    well its been useless for a while
    wpa has its weaknesses as well
    radiator the bloke over the road might be running security inside the network like i do here :)
    a vpn setup is much better though may not be practical for a "normal" home network
  4. Glider
    Glider /dev/null
    2 Aug 2005
    WEP has been relatively easy to crack a long time. Certainly if there's some activity on a network... WPA is a lot more secure, and I haven't got any knowing of a succesfull crack on a WPA network, without pre-knowledge that is. But, nothing is 100% secure. If you are one of the security freaks, go WPA with a Authentification server and stuff...
  5. Matkubicki
    Matkubicki What's a Dremel?
    18 Jan 2005
    I've always used WPA with a pre shared key, i'm hoping this is reasonably secure although i don't know a huge amount about these things. Around here theres no shortage of totally unsecure wifi, infact all over the country i've had no problems getting online just by parking up in a street with a few houses and connecting to the nearest open network. Who needs Cloud or OpenZone or whatever with all this free internet!
  6. airchie
    airchie What's a Dremel?
    22 Mar 2005
    What kinda security you using?
    WPA is about as simple and secure as it gets, assuming all your stuff supports it.
    The only real weaknesses it has is that it's susceptable to brute-force attack but since you can use up to 63 chars (IIRC) in the password, brute-forcing should take a very long time if you use a decent password.
    I certainly think, for home networks its the way forward since who's going to bother trying to crack it when they can use someone's network that has no security?
    Also, on this subject, MAC address filtering and SSID hiding are useless as security measures.
  7. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    bah, my network has a older first gen centrino in it (with only B support not G!), hence I'm kinda stuck with WEP... ¬_¬ fortunately there is not a single person round my area with a network - either thy're all leeeching off me (unlikely, I check my router options from time to time) or they cant be assed getting wireless. Anyways, if anyone knows how to get WPA/2 on the older centrino let me kno, cheers.
  8. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    hah, he got the name wrong. it's Mark Handley, he taught me Operating Systems this year :)
    andreas Bittau also gave a few of our lectures.
  9. airchie
    22 Mar 2005
    huh? :D
    dragontail, you just need to have XP with SP2 to get WPA going on an older centrino AFAIK. :)
  10. tacticus
    14 Jan 2006
    archie wpa + seperate network
    and a linux box that hands out dhcp address
    it also blocks all connections except for an ip that isnt in the dhcp range
    and then allows a vpn into my network :)
  11. airchie
    22 Mar 2005
    sounds safe enough then... ;)
  12. tacticus
    14 Jan 2006
    i run a business from it :) and most people dont have a nice 28 port linksys switch with vlan support and 2 servers running 8 virtual machines :)
  13. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    I don't bother with encryption at all.
    MAC denial is where its at ;)
  14. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    but its easy to spoof MAC addresses...
    when i was living in a house in reading, all the networks round us were insecure, and all but one had the default password on their routers...
  15. Sam0r
    24 Jun 2005
    Yeah, its easy but its the hardest out of the alternative methods of security.
  16. Callum
    Callum What's a Dremel?
    4 Apr 2006
    I never understood the big deal. Sure, someone can break into your network with a little time and effort, but what the hell is the point on a home network? What are they gonna do? Listen to my music without without permission? :p
  17. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    Hack into your computer and retrieve banking info, and misc. info stored on your computer of great importance?
  18. Cabe
    Cabe What's a Dremel?
    14 May 2002
    WPA with TKIP Preshared keys does it for me, with a sprinkling of MAC address lists as well.
  19. fev
    fev Industry Fallout
    13 Aug 2003
    Use my bandwidth, which i want to use myself!
  20. Agamer
    Agamer Minimodder
    10 Mar 2005
    Except it's not. To spoof a MAC address it really really easy. So it basicly offers next to no security....
    My personal home network is protected by a 63 character long passcode randomly generated and uses WPA. I have been considering using vpn as well just because I can...
