News Western Digital introduces new GreenPower HDDs
Discussion in 'Article Discussion' started by Tim S, 24 Jul 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Marketing BS.
    If you want to use less power, get solid state!
  3. Glider
    Glider /dev/null
    2 Aug 2005
    ..Or turn of your PC when you don't need it...
  4. Guest-16
    Guest-16 Guest
    But where does it get to the point where we're not allowed to fart without planting a tree?
  5. RTT
    RTT #parp
    12 Mar 2001
    Good luck getting big capacities then.. for the time being :D
  6. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    sure we could go solid state. nothing like paying $8k for 512gigs of space
  7. Jamie
    12 Mar 2001
    You know it will come down in price, look how cheap USB/stick memory is.
  8. bilbothebaggins
    bilbothebaggins What's a Dremel?
    1 Sep 2006
    Of course, the PSU will have to actually translate that power saving over to the plug ...
  9. TheVoice
    TheVoice What's a Dremel?
    14 May 2007
    True, speeds need to increase too though. Bit-tech's own review of that SSD drive the other day didn't impress me much.
  10. RTT
    RTT #parp
    12 Mar 2001
    Uh, well, unless i'm missing something, that's exactly what'll happen. Efficiency aside, it isn't like the PSU is constantly sucking 500W (or whatever) and burning off anything you aren't using in heat/noise etc.
    More than happy to be corrected/proven wrong though :)
  11. Glider
    Glider /dev/null
    2 Aug 2005
    You are correct, but efficiency drops quite a lot when the PSU isn't under plenty of load.
  12. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    I would have thought that the PSU would be more efficient under less load, as the unit runs cooler etc, so thus less heat given off and well more energy efficient :geek:
  13. Nexxo
    23 Oct 2001
    ^^^ Correctemundo.
    Moreover, people are forgetting another benefit (besides laptop applications) of a 40% drop in power requirements: a 40% drop in heat generated. Think about it.
    Not quite as simple as that. We need more robust flash memory that can stand a lot more re-writes. We also need it to work faster. We need FRAM.
    FRAM memory chips have memory cells that contain a specific ferroelectric material such as a crystal of zirconium or titanium, or oxygen and lead. FRAM is much faster than Flash, and has a near-unlimited number of write-erase cycles. Unfortunately chips produced are still at the Mbit, rather than Gbit stage...
  14. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i like more efficient hard drives, i am thinking of buying one.
  15. Amon
    Amon inch-perfect
    1 Jun 2007
    Definitely useful for the datacenters while still moderately useful for home use. It would be great if entire neighbourhoods just used these drives for mass storage.
  16. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    When I built my current rig I went with a WD hard drive for the main one and after a while discovered that some intermittent stability problems I was having likely came down to the hard drive overheating, I have since rearranged the components a bit to provide it with better airflow and switched the primary hdd over to a similar samsung spinpoint.
    Now given my experience, where heat (and maybe a touch of noise) were the only complaints I had about the WD hdd, I'm not too surprised that they seem to have put some effort into getting the heat down :)
  17. hitman012
    hitman012 Minimodder
    6 May 2005
    The unit running cooler has little to do with it, as efficiency is simply the ratio of input energy to useful output. It gives off less heat in absolute terms, but what you should be looking at is the heat output as a proportion of the input power.
    Compared to linear regulators, the switch-mode power supplies in computers do not have a linear relationship between power and efficiency. It looks something like this (image stolen from Coding Horror):
    You can see that at lower output levels the efficiency drops quite significantly, whereas the peak efficiency sits at around 50-60% of the rated output.
  18. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Efficiency of pretty much any PSU not in the 80+ club is near abysmal at lower outputs. The closer you get to its theoretical max, the less energy is being wasted in the constant discharging. That's the beauty of 80+ PSUs, though....they have to be at least 80% efficiency across their load spectrum.
  19. completemadness
    completemadness What's a Dremel?
    11 May 2007
    yeah as said above, 50-60% is about the sweet spot (people usually say about 2/3 - it depends on the PSU)
  20. mattthegamer463
    26 Nov 2004
    Nerd. :)
    I agree with Jamie, its BS. If we focused on developing renewable sources of energy quicker we wouldn't be making a carbon footprint. If we had 10 trillion wind turbines and had 1000 times more power than we could ever need, wouldn't we all be leaving our computers and lights on constantly?
    Electricity is not bad, the way we make it is. People need to keep that in mind to avoid marketing gimmicks.
Tags: Add Tags
