Modding Wewt Wewt First Vfd
Discussion in 'Modding' started by Drastik, 28 Apr 2002.
  1. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    i ordered my first vfd from bgmicro. its a 2X20 vfd it is serial and paralell. $19.95 USD not bad. i question where do i get the polarizing film in the us and how do i mout tihs bad boy.
  2. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    Dunno about where to get the film in the US, but i mounted my 2*20 using a load of hot melt glue.
  3. macroman
    macroman The One
    3 Sep 2001
    Why do you want polarising film for a VFD?
  4. bLiNdPyRo
    bLiNdPyRo What's a Dremel?
    31 Dec 2001
    Considering how large that VFD is, I don't think you'll be able to mount that in a drive bay. Most people just mounted them externally in acrylic stands or something. By the way, VFD polarizing film? Aren't VFDs already legible enough to not need that? If you're talking about inverting them, I'm not sure you can, I haven't seen anybody do it yet.
  5. Thorfinn
    Thorfinn What's a Dremel?
    18 Mar 2002
    Are you talking about a filter?
  6. Forsaken
    27 Mar 2001
    My 2*20 sits fine in a drive bay with lots of spare room....
  7. cderalow
    cderalow bondage master!
    23 Jan 2002
    maybe the dimensions of the bg micro one should be mentioned... they're about 8x3... roughly... barely fit in some of the smaller (narrower) cases out there
  8. Drastik
    10 Jan 2002
    ya i need the filter
  9. bLiNdPyRo
    31 Dec 2001
    Like cderalow said, I was refering to the BGMicro VFD.
  10. fat mike
    fat mike What's a Dremel?
    29 Apr 2002
    I found some thin blue plastic at a craft store to use for my filter
  11. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    surely it can't be serial AND parralell
  12. i_h8clowns
    i_h8clowns <img src="http://www.bit-tech.net/ataraxia/it.gif"
    9 Sep 2001
    it can be run via serial OR parallel but most people go serial cuz it only requires 3 wires to hook up.
    i'm going to use lighting gels to filter my VFDs. they are used in theatre to filter spotlights, etc. there's a theatre/stage lighting shop near where i live where i'd get my stuff. the two most popular gels are roscolux and GamColor.
  13. Digital Fodder
    Digital Fodder What's a Dremel?
    30 Aug 2001
    i just got mine though the post, still cheaper than anywhere else and i live in the UK. You want filter if you want different colors for the VDF, if you live in the UK then maplin sell the stuff (just bought some) but there outta stock of the dark blue :sigh:
    It can be both serial and parallel, most people choose serial because you get a full 10 custom character set, but with parallel you only get 4...so when you run that winamp plug-in if goes funny (i think thats how it works - takes a long time to read 80 pages on a forum). Plus serial is waaaaay easer to wire up.
    If you need any info on the VDF check the [H]ard forums.
  14. boycee
    boycee What's a Dremel?
    9 Jan 2002
    Digital Fodder
    are you UK ??
    if so how much did it cost all in all,
    inc postage, tax, duties ETC the TOTAL.
    I'm also looking at getting that as its dirt cheap.
    Let me know cheers.
  15. dakar
    dakar What's a Dremel?
    6 Mar 2002
    Drastik Thanks for the post... i just order me one to play with. Looks like a pretty sharp little unit and the price was right.
    bLiNdPyRo: BTW it is already capable of being inverted.. its built right onto the board...
    Now the really hard part...waiting for the ups guy to bring it to me
  16. boycee
    9 Jan 2002
    let me know when u get it, as i want to avoid getting stung on tax and duties again.
  17. boycee
    9 Jan 2002
    Digital Fodder
    just got your reply on Hardforum, cheers.
    Mines On its WAY !
    YAY:D :lol:
  18. dakar
    6 Mar 2002
    Mine arrived in the mail today :D :D
    Anyone have a quick and easy pin-out to wire her up? What would be better serial or parallel?
  19. Digital Fodder
    30 Aug 2001
    heres mine...
  20. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    <<BTW it is already capable of being inverted.. its built right onto the board...>>
    how so ?
    show me :D
