News WGA defeated before rollout
Discussion in 'Article Discussion' started by GreatOldOne, 24 May 2005.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
  2. kenco_uk
    28 Nov 2003
    Whatever will they think of next? *coy expression*
  3. Bob 1234
    Bob 1234 What's a Dremel?
    5 Aug 2003
    Told ya so. :D :p
    -Bob
  4. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    :D Oh, look, another M$ anti-piracy inconvenience that fails miserably.. ;)
  5. Haddy
    Haddy World Domination
    22 Jan 2002
    Now did they post that report to MS or did they just post it to the internet?
  6. kergareth
    kergareth What's a Dremel?
    6 Jul 2004
    Does it really make a difference?
    Microsoft will read it either way.
  7. Firehed
    15 Feb 2004
    MS: owned as usual.
  8. advance
    advance What's a Dremel?
    18 Apr 2005
    Called it ;p
  9. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    hmm lasted a while thou, the bad part is he pulled the algo which is able to determine if a cd key is one of their legit ones oopsie!
    people bashing MS, show me an anti-piracy software thats able to never be broken, i know some people who will make us a billion within a week (and i'm not kidding about that! the problem is its your PC, the copy protection software is a virus, which you can just patch round because you where inside the CPU/HOST-OS first).
  10. Firehed
    15 Feb 2004
    Wait a second... if I read that right, MS is now worse off than before since more illegal keys can be generated. re-lol. Didn't read the full thing so I'm assuming they'll pull that... whatever...
  11. simon w
    simon w What's a Dremel?
    3 Nov 2003
    They've basically released a keygen for their own product :D
  12. Firehed
    15 Feb 2004
    Well you still need to pirate the software itself, and I think it's safe to say most pirated versions include a keygen or have been cracked to not require activation. But yeah, funny how they pulled that off.
  13. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    its all due to the fact you can read the machine code algorythm for the key validation, then once you understand it, you can either reverse engineer the algo to generate keys from a seed, or you can just one step away from copy & paste brute force run every number down the algo, and keep those which work.
    Now any form of inteligant critisim would be "why wasn't that been done on the server side" Ie, why wasn't the key be transmitted in a public private key manner to the server and the validation performed on the server.
    the problem with this is, it relies on the information been transmitted to be true. How do you actually make a program that knows its not running on a vritual layer on the system to probe the system? The only way to do it is to make soo many differen't version which don't have enough smililarities for the same solution to work on all them.
Tags: Add Tags
