Displays What’s your IPS story?
Discussion in 'Hardware' started by Siwini, 3 Aug 2011.
  1. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    Just a little input on my u2410. After about month or so using it I can’t stand TN monitors. Working became literally difficult now sitting behind 19’ TN monitor is a long day of torture. My eyes literally hurt now I lose focus after few hours and have to take break. I really have to try and concentrate on what I’m looking at using TN panel. I checked if I needed glasses, but no that wasn’t it. Putting glasses made it even worse. As soon I come home from long work day, sit behind my system everything is so much clearer and brighter. Also playing games, watching movies and everything in between is so super now. All I can say is WOW! So what’s your IPS story?
  2. pac-man
    pac-man What's a Dremel?
    5 Sep 2010
    Interesting to hear about your story. Can't you ask work to buy you an IPS screen? If it's affecting you that badly then surely your employer needs to do something about it under health and safety laws.
    Regarding my story, I was going to invest in a 3D monitor for gaming then soon found out the colour quality wasn't great. After much research I eventually came to the realisation that the 3D effect would wear off me pretty fast. I then came across IPS screens said to have better colours and the ability to view from different angles without losing much colour. Once I found out there were a couple affordable options I went for the Dell U2311h and have never looked back.
    I mainly use it to game but I do see the difference when comparing to my older 19" TN.
    aNuclearPidgeon likes this.
  3. Siwini
    14 Sep 2010
    Are you using sRGB or Adobe RGB mode?
  4. G0UDG
    G0UDG helping others costs nothing
    27 Mar 2010
    Same here my old monitor was an old yusmart 19" screen 1280x1024 the colour was awful and response time was 16ms input lag wasnt too bad I guess,I now have the Dell Ultrasharp U2410 REV A05, and WOW what a difference colours are bright and accurate with no colour bleed and I get little-no eye strain even after long sessions of either gaming or video editing. I have the monitor on game mode RGB and it works just fine for everything
  5. LennyRhys
    LennyRhys Oink!
    16 May 2011
    I've had several TN monitors over the years but now I use two NEC LCD2490WUXi2 24" H-IPS displays for my photography business; TN simply wouldn't work for this. I had considered getting a 30" display but I much prefer the two 24" screens for workflow.
    I'm definitely not in the "TN sucks" camp though; I would be quite happy with a large TN display as part of a gaming system. I used a HannsG 28" for nearly 2 years and I loved it.
  6. wyx087
    15 Aug 2007
    my IPS story started out on my iPhone 4 on its launch day. love its colours, love its viewing angle and love every bit of it.
    2 months later, got the U2711, and my god what brilliant colours. it puts iPhone to shame with its vivid and accurate colours. my work's PVA isn't down right bad, but now its colours feel dull.
    fast forward to a few months ago, where i finally fed up with my netbook and bought an iPad 2. no where near as good as the monitor, but still comparable to iPhone 4's screen.
    basically, i've rid of all TN panels from my possession over the last year. it really is a slippery slop.
  7. camelCase
    camelCase What's a Dremel?
    22 Apr 2011
    Have you tried looking on an ergonomics website to see if everything is set up right for using the monitor? Check things like distance to the monitor, brightness of the monitor and the room and position of your eyeballs. I know it sounds dimb, but if you have to raise or lower your eyes to see the screen properly, certain parts of the eye that are normally kept covered and moist are exposed to the drying elements of the air and can cause problems.
  8. Elton
    23 Jan 2009
    Found a $15 IPS (original IPS from 2003) NEC monitor. Tried it out, still beat TN monitors of a newer caliber.
    Afterwards, got a 19" S-IPS, then a 20" S-IPS and another 19" S-PVA.
    I love cheap used NEC monitors. :D
  9. pac-man
    5 Sep 2010
    I'm actually not sure. I didn't really change many settings out of the box. How do I find out?
  10. GoodBytes
    20 Jan 2007
    Press the menu "button" (touch sensitive) above the power button. When your finger comes close to the power button, or any of these touch sensitive buttons, the menu button will illuminate blue. Press on it, and the monitor menu will appear, and the other buttons will illuminate and instructions on what the buttons do on the screen, right next to each button.
    From there select "Menu", and then go under "Color Settings". From there you can pick which color profile you prefer. Use Adobe RGB or sRGB at your liking. Adobe RGB = sRGB with a bit more saturation on the colors. Of course, I am talking here at a non-professional level. A pro have specific purposes for either (then again, pros don't use this monitor, and go for a several thousand dollar monitor of the same size, and of course better (well better be for several thousands of dollars).
  11. Pookeyhead
    30 Jan 2004
    I got fed up with poor viewing angles and "glow" with the blacks, and got rid if it for a S-PVA panel instead. Much nicer :)
  12. longweight
    7 May 2011
    TN Panels don't suck, I use 2 at work and they are fine for day to day tasks but at home I have my U2711 and its awesome :D
  13. Abhorsen
    Abhorsen Minimodder
    10 Apr 2008
    Pron looks great on an IPS panel...
  14. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    What about gaming on ips? Anyone found downsides when playing games?
    Sent from my GT-I9100 using Tapatalk
  15. wyx087
    15 Aug 2007
    downside for me with U2711 is that it's too big. i get motion sickness when i try to play console games with incorrectly set FoV.
    Sent from a computer that no one else cares.
  16. Parge
    16 Jul 2010
    You find you actually have to look around the screen with your head?
  17. longweight
    7 May 2011
    :naughty:
    Wouldn't know about 2560 x 1440 pron....
  18. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    My aunt is a medical researcher, and she has an HP ZR24w in her office. That was a pleasure to view, even if only to check my email.
    /gazes sadly at an all-TN household (though we have an S-PVA Samsung TV). The problem is that it's not a mainstream technology and the home budgets do not allow for extra expense on IPS monitors. Laptops too are an all-TN affair unless you spec it as an option on premium ThinkPads.
    Sent from my GT-I9000 using Tapatalk
  19. rv88uk
    rv88uk What's a Dremel?
    28 May 2011
    For those with ips panels, would you say the upgraded colours are worth the price of admission alone? I've got a 2707wfp at the moment, which is by no means a bad monitor, but the feedback regarding the U2711 makes it sound seriously tempting.
  20. pac-man
    5 Sep 2010
    Hi,
    Yeah I checked that and got 2 options: RGB or YPbPr, RGB is currently selected. I've been pretty happy with the colours since I've got the monitor and haven't really needed to tweak anything.
