Graphics What AGP graphics card for £170?
Discussion in 'Hardware' started by cpu121, 13 Jul 2005.
  1. cpu121
    cpu121 What's a Dremel?
    25 Nov 2003
    I'm looking to upgrade the system in my sig to play Battlefield 2. I'm also intending to do a complete upgrade later in future (say Christmas time/early next year) but right now I intend to get BF2 working on the system. My budget is about £170 and I'm looking for a middle of the range card rather than a high performance one. One important requirement is the need for 2 outputs (either 1x VGA 1x DVI or 2x DVI).
    I've looked around at a couple 6600 GT cards but the only direct comparisons between them have been for the PCI-Express cards, and the ones that did have AGP counterparts didn't get decent reviews, so anyone know of any decent 6600 GT (or the ATi equivalent - I guess X800?) that use AGP?
  2. Tim S
    Tim S OG
    8 Nov 2001
    You can get a GeForce 6800 for £159.99 from LowestOnWeb :)
  3. cpu121
    25 Nov 2003
    How would that compare to a 6600GT 256MB etc? Value for money is my main consideration, no point spending more if it doesn't give much better performance in today's games.
  4. Tim S
    Tim S OG
    8 Nov 2001
    It depends how necessary you feel 256MB of memory will be... in 12 months time, it'll be reasonably necessary... right now, I don't think so. :)
  5. phuzz
    phuzz This is a title
    28 May 2004
    lowestonweb ain't if you get my drift, look around and you'll find stuff cheaper, personally I'd have a look for a decent ATI card, like maybe this one? (ok so it's £4 over budget before p&p, but...)
  6. cpu121
    25 Nov 2003
    Hmm, that's a consideration. It's bad enough trying to figure out Nvidia's naming system let alone ATi and all the resellor's, so it's nigh on impossible to know which card is which and is it better than that model without reading through all the specifications.
    A mate of mine suggested I upgrade the RAM as well since BF2 seems to struggle on his 512MB until he got another stick. So if I was to buy another 512MB stick (£30) that would bring a 6600 GT or thereabouts back into consideration as well.
    God, I'm useless at making these kinds of decisions! :wallbash:
  7. Tim S
    Tim S OG
    8 Nov 2001
    you will benefit from more system memory without doubt IMHO.
  8. chemo
    chemo True Jungle Brother
    20 Feb 2005
    go with the nvidia 6800, its got newer hardware than the ati's.
    (shader model 3.0 & hdr capabilities too)
  9. cpu121
    25 Nov 2003
    Thanks for the replies. Any siggestions for a 6600 GT or the ATi equivalent since most results on Google tend to be about the PCIe versions?
  10. alastor
    alastor Minimodder
    6 Sep 2004
    If you can stand to buy from OCUK, they have a Leadtek 6800GT for £165inc VAT at the moment. Would beat anything else mentioned so far...
    http://www.overclockers.co.uk/acatalog/Leadtek_SALE.html (about 2/3 way down: Leadtek WinFast GeForce 6800 GT 256MB DDR3 TV-Out/DVI (AGP) - Retail)
  11. Tim S
    Tim S OG
    8 Nov 2001
    damn, I was just going to post that Alastor... amazing deal!
  12. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    I saw this one too, but noticed that the core speed was lower than the 6600GT of other makes? I guess it makes up for it in other areas?
    I've been so out the loop on cards its unreal and so confusing :confused:
    Most of them seem to beat me old 9800pro hands down. With a new card and say another Gig of RAM and I'll be laughing :D
  13. Tim S
    Tim S OG
    8 Nov 2001
    Spawneh, the linked card is a 6800 GT, not a 6600 GT ;)
  14. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
    surely thats even worse if a 6600gt has a higher clock speed than a 6800gt?
  15. Tim S
    Tim S OG
    8 Nov 2001
    No, GPU's work on parallelism - a GeForce 6600 GT only has 8 pixel pipelines and can only write 4 pixels per clock. A GeForce 6800 GT has 16 pixel pipelines and can write 16 pixels per clock. Typically, the GeForce 6800 GT is about twice as fast as a GeForce 6600 GT.
  16. [GiB] Spawny
    2 May 2001
    I thought the 6600gt had 16 pipes if thats not the case the 6800gt would be a better option.
  17. TMM
    TMM Modder
    12 Jan 2004
    6600GT - 8 physical pipes, 8 pipes unlocked
    6800LE - 16physical pipes, 8 pipes unlocked
    6800 - 16 physical pipes, 12 pipes unlocked
    6800GT - 16 physical pipes, 16 pipes unlocked
    So yea, any 6800 card is going to be faster then a 6600 even if the clocks are lower (except for 6800LE and if you got a really lower clocked 12pipe card but they arn't available anyway afaik..:p)
  18. Tim S
    Tim S OG
    8 Nov 2001
    the 6800 LE and 6800 Std are slightly different in their PCI-Express form there are only 12 physical pipelines inside the GPU.
